My Problem: When i log on to my laptop it runs for about an hour and then shuts down completely. Sometimes it can run for longer or shorter
I've lost a lot of work due to this
I have a Samsung R505 Vista premium
Can Someone help me please!!
Hello MessyGuy,
It sounds like you may be having a overheating issue. You can get a can of compressed air and see if blowing out the dust in the heatsink vents on the laptop may help. Plus, to keep the vents clear and free while in use. Check in your Advanced Power Plan settings (Control Panel) and look in your "System Cooling" options. You may need to use "Active" instead of "Passive". If all else fails, they have "laptop cooler fans" that can attach to your laptop to help keep it cooler to help prevent it from overheating.
This is for Windows 7, but it's the same steps in the Control Panel (Start Menu).
Power Plan Settings - Change - Windows 7 Forums
It should be under the "Processor power management" folder tree.
It doesn't look like you have this option, and would need to try the other suggestions instead to see if they may be able to help with this if it's a over heating issue.![]()
| Similar Threads | ||||
| vista boot up problem, pls help ASAP | jokesy | Vista performance & maintenance | 5 | 21 Jul 2009 |
| Vista installation problem,, i need help ASAP | Hussam | Software | 26 | 05 Jul 2009 |
| Vista installation problem,, i need help ASAP | Hussam | General Discussion | 10 | 22 Jun 2009 |
| Problem with some services! HELP MEEEE ASAP! | giwrgos | Network & Sharing | 0 | 11 Feb 2009 |
| Help Urgent Asap Asap Asap | George M | Vista General | 13 | 31 Oct 2007 |
