SONY VAIO VGN AR 630E - card reader problem
George73
Dear friends
Please help me to solve the problem with card reader. System VISTA HOME PTEMIUM 32 bit. I fight with this problem few weeks. Manufacture is Texas oinstruments - PCI XX12. I foun some information at webside, make installation of different drivers version: 2.00.6, 2.00.7, 2.00.9, 2.0018. but it still dosn't solve my problem. I can't read any SD - cards. There is information: please format the card.
I made also changes at regedit: from 16 to 1 but still the same problem. Maybe it's IRQ problem?
Hello George73,
Has this just started happening, or has it never worked ?.
Have you formatted the card ?, right click on the card and choose format, let it run through the process and try the card.
Also, go to the Device Manager and look for any yellow triangles.
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
Hello George73,
It worked ok untill download SP2 for VISTA.
I tryed to format the card but it's immpossible. When I connect the card by USB - card inside of photocamera it works good. There is no yellow triangles at Device Manager.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
I made it and found at the file sfcdetails.txt problem:
2010-02-16 00:55:15, Info CSI 000001b0 [SR] Beginning Verify and Repair transaction
2010-02-16 00:55:18, Info CSI 000001b2 [SR] Verify complete
2010-02-16 00:55:18, Info CSI 000001b3 [SR] Repairing 1 components
2010-02-16 00:55:18, Info CSI 000001b4 [SR] Beginning Verify and Repair transaction
2010-02-16 00:55:18, Info CSI 000001b6 [SR] Cannot repair member file [l:24{12}]"shellbrd.dll" of Microsoft-Windows-Branding-Shell-HomePremium, Version = 6.0.6000.16386, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-02-16 00:55:18, Info CSI 000001b8 [SR] Cannot repair member file [l:24{12}]"shellbrd.dll" of Microsoft-Windows-Branding-Shell-HomePremium, Version = 6.0.6000.16386, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2010-02-16 00:55:18, Info CSI 000001b9 [SR] This component was referenced by [l:210{105}]"Microsoft-Windows-Branding-HomePremium-Client-Package~31bf3856ad364e35~x86~~6.0.6000.16386.BHPC Namespace"
2010-02-16 00:55:18, Info CSI 000001bc [SR] Could not reproject corrupted file [ml:520{260},l:64{32}]"\??\C:\Windows\Branding\Shellbrd"\[l:24{12}]"shellbrd.dll"; source file in store is also corrupted
2010-02-16 00:55:18, Info CSI 000001bf [SR] Repair complete
2010-02-16 00:55:18, Info CSI 000001c0 [SR] Committing transaction
2010-02-16 00:55:19, Info CSI 000001c4 [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired
I think you need to try and format the card.
Do you get an error number when you try ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
I try few times but there is no results. It takes long time and finally is information that windows is unable to format the disk. There is no error number. The same card connected by USB with photocamera is working. Memory stick is working just SD card reader can't work !
