window media player problem
yvesj
do i need to use only a new cd .blank cd .
i have been trying to burn music on a cd with song on it .
is this is why i cant not burn music on it .
thank you
    build by me last summer
    cpu.3.00.ghz
    asrock fm2 -75 pro
    g-skill 1333 7-7-7-21 4 gbs
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    apevia.atx-as500 blue led
    thermatake armor a 30
    5= 80 mm led fans
    logitech mk 300
    logitech
i don't see any thing like he said after i go in my computer then dvd rw drive d: audio cd.
he to click on it and i should see erase dish .
but that do not come up
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech mk 300
    logitech
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech mk 300
    logitech
Think you're out of luck with that CD. It was created as an Audio CD, and finalized. You'll need a blank one or one that was formatted as "Live File System", rather than "Mastered".
Ed
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE
    1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech LX710
    Logitech MX100 Laser
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
Wow nice badge, you just got Ed, congrats.
yes i did some reading and they all say to put in a blank cd in .
so this was my problem .
i was trying to use a cd with song on it .
tomorrow i will go and buy some new cd .
thank you for your help
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech mk 300
    logitech
ok i did buy new cd .
no problem now to burn music .
working really good .
thank you all
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech mk 300
    logitech
Glad that you solved the problem.
ho yes that did it for sure .
well this guy at let me a dvd-rw .but he never said that he window 7 on it .
hello there .
when he even install my window 7 using the cd i buy for 140.00 .
i was sure that i was not to good with a computer .
but i thing he is way worst then me .
this is why i could not download music on it .
and my other cd -r i know i had some music on it .
thank you for the help .
    cpu.3.00.ghz
    asrock fm2 -75 pro
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    5= 80 mm led fans
    logitech mk 300
    logitech
