V valytzu01 New Member May 29, 2010 #1 i have a problem with system properties. if someone can solve this problem i will thank him.please help me Attachments Untitled.jpg 107.7 KB · Views: 64 My Computer System One
richc46 Vista Guru Gold Member May 29, 2010 #2 Let me know results trying to access with clean boot. How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7 If you still cannot access try this: Type cmd in search. Do not hit enter, run as administrator. In cmd type this sfc /scannow. My Computer System One Manufacturer/Model Dell XPS420 Memory 6 gig Graphics Card(s) ATI Radeon HD3650 256 MB Sound Card Intergrated 7.1 Channel Audio Monitor(s) Displays Dell SP2009W 20 inch Flat Panel w Webcam Hard Drives 640 gb Cooling Fan Keyboard Dell USB Mouse Dell USB 4 button optical Other Info DSL provided by ATT
Katokato Banned May 29, 2010 #3 run this reg file, restoring the association of msc and cpl files. make a system restore point first, if in case something gets screwed up good luck post your results Attachments xp_cpl_file_assoc.zip 482 bytes · Views: 3 xp_mscfix.zip 788 bytes · Views: 3 My Computer System One Manufacturer/Model Hp pavillion a6110n CPU amd athlon 64 x2 live! 4400+ Memory 4 gigs 3.3 useable Graphics Card(s) Finally! SAPPHIRE 100283L Radeon HD 5770 (Juniper XT) 1GB 12 Monitor(s) Displays generic pnp monitor Screen Resolution 1280x1024 Hard Drives 7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition PSU 500W, antc earthwatts EA500 Case normal black case Cooling fans Keyboard saitek cyborg gaming keyboard Mouse logitech mouse (small to fit hand perfectly) Internet Speed dsl Other Info 2.3 ghz amd
