I think that it may be a broken association with .exe. If so this will correct the problem. Default File Type Associations - Restore
If that does not work, it may be registry. My advice would be to use system restore from a week before the problem
Long Beach CA
Windows Vista Home Premium 32bit
Local Time: 01:36 AM
Re: shortcut problems
It might be your computer lagging. Give it some time to cool down. If you can't move your mouse, it probably froze so you should turn off your computer. Hope this helps!!!
-Derek
System Manufacturer/Model Number IDK OS Windows Vista Home Premium 32bit CPU IDK Motherboard IDK Memory 2 gb Graphics Card IDK Sound Card IDK Monitor(s) Displays IDK Screen Resolution Full screen
Keyboard IDK Mouse IDK PSU IDK Case IDK Cooling IDK Hard Drives IDK Internet Speed Pretty quick Other Info I like playing a LOT of video games. I also like to play with friends, study to learn, and learn new things. :)
