Magik
Sorry if a thread already exists. I'd looked for one similar to my problem, but couldn't find one that exists that isn't closed...
With that being said, I am running a Vista Home Premium 32-bit & the External Hard Drive I'm having problems with is a Seagate 250GB. The box it was in says 'Expansion'. I've looked over on Seagate site & found no help.
Here's the problem- 2 days ago, my external wasn't showing up on my computer at all. After searching & following tips here & there on the web, I finally got it to show up. I ended up doing the following: 'cmd' as Administrator:
"chkdsk x: /f /r" and press "Enter," substituting "x" with the letter of the USB drive.
From there it scanned the drive & it showed up. The next problem was no permissions to move anything or access anything on the drive. Again, I typed the following commands as Admin. in the command prompt:
cacls H: /E /T /C /G Administrators:F
takeown /f H: /r /a
This gave me 'some' permissions, but not all. I still am finding myself having to manually click on properties to some folders to try to get ownership/ gain permissions. However, with some I get the following error codes:
Other files or folders I try to move, I get the following error:
And some folders I can't open:
I've noticed that the multiple times I attempt this, I've been looking at the manage window & sometimes it says the external drive is 'healthy' & other times it shows as 'RAW'.
At the time of my posting, this is how it looks now:
I have already lost some data on it & I've tried to recover it, using Recuva software as well as others, only to get the I/O error:
I've also clicked on the drive, itself & went into Properties/ Tools & checked for errors.
I've tried using the Seagate Seatools, but it won't scan it.
I run a couple fansites & everything (my life!) is on this external. I had all my data on another external, but that drive failed as well & this one was my backup. Aside from cutting my losses, etc., is there anything else that I can do that I haven't already done? I've been doing everything I can for the past 2 days & any help would be greatly appreciated.
takeown /f H: /r /a
- Acer Aspire 5720Z
- Intel Pentium Dual CPU T2370 @1.73GHz
- unknown
- 2.00 GB
- Graphics Card(s)
- Unknown
- Unknown
- 250 GB (unknown brand)
250 GB Seagate external (2)
- Case
- Laptop
- Logitech
