Fan Speed
  1.    27 Apr 2011 #1
    Vista x64 Home Premium SP2
    Local Time: 14:03
    usa us massachusetts
    Fan Speed
    So I took a look through this section and found SpeedFan. Thought about how my computer sometimes can gets very hot and can edge on overheating (according to CoreTemp) so I decided to give it a go.
    But it doesn't list my motherboard. I dig some digging and my motherboard is an Intel GL40. So any alternative programs to do a similar goal as SpeedFan?
  2.    27 Apr 2011 #2
    Ultimate x64, home Prem 64
    Local Time: 15:03
    canada
    Re: Fan Speed
    What are you trying to do? That mobo part is for overclocking.
    Speedfan is for possibly controlling the fans.
  3.    27 Apr 2011 #3
    Local Time: 14:03
      Thread Starter
    Re: Fan Speed
    Quote Originally Posted by Patonb View Post
    Trying to reduce overheating. I been monitoring my temperatures with Temp Core and all that and it edges close to overheating on good occasions (Single digits or low teens to TJMax).
  4.    27 Apr 2011 #4
    Arizona
    Windows Vista Home Premium 64 bit Sp2
    Local Time: 12:03
    usa us arizona
    Re: Fan Speed
    Hello here are a couple of sites for you to look at.
    Core Temp
    CPUID - System & hardware benchmark, monitoring, reporting
  5.    27 Apr 2011 #5
    Local Time: 14:03
      Thread Starter
    Re: Fan Speed
    Quote Originally Posted by americancritic View Post
    Core Temp
    I currently have tired both of those actually. I am using Core Temp right now to monitor what is up with it. (Typoed it as Temp Core).
    I also deicded to open up the panel covering up the motherboard and bit a bit of cleaning to it. Blew at it and quite a bit of dust came out. I blew at the vents on the side and there was a lot. SO far that has as far as I can see improved the performance of the fan a bit. I'll try more to see what happens.
  6.    27 Apr 2011 #6
    Local Time: 15:03
    canada
    Re: Fan Speed
    youre not going to use a program to do what you want.
    Youre best option will be a cooler.
  7.    29 Apr 2011 #7
    Local Time: 14:03
      Thread Starter
    Re: Fan Speed
    Quote Originally Posted by ChaosDark View Post
    It seems this did quite a bit of magic. It is sometimes the simpliest of solutions that you overlook and completely disregard that gets results (It is now like ~20 degrees cooler)
  8.    29 Apr 2011 #8
    Local Time: 15:03
    canada
    Re: Fan Speed
    Yha, i had my acer shutting down because the gopu overheated.
    Cleaning helped it go bye bye.
  9.    29 Apr 2011 #9
    Arizona
    Local Time: 12:03
    usa us arizona
    Re: Fan Speed
    If you use compressed air do it in short bursts not full out.
Fan Speed
"slow speed" "natural speed" do not show
Dear all~ I am at this website.
Sound & Audio
Can you speed up download speed from ISP
Is it possible to increase the download speed from an ISP without using rubbish software which generally have Malware with it? One word answers...
General Discussion
Vista Home Premium. Admin Account WiFi Speed Good. Other User Account Speed Not So Good.
I have two accounts setup on my laptop, one for myself which is the admin account and another for my wife. My laptop can connect to my router...
Vista General
Help! Vista Home Premium. Admin Account WiFi Speed Good. Other User Account Speed Not So Good.
Vista networking & sharing
Network speed is half or one third of speed on XP
I have a desktop dual boot with XP and VistaSP1 and a laptop with XP, when I move files from XP to XP via network the speed os fast when I...
Vista General
How to speed this up. ;-(
Hi, I'm using Outlook Express under Windows XP. In several of these groups, I've all messages. All together up to 2 GB. My ISP has a high...
Vista mail
How to check your Speed Boost tested memory speed
Just in case anyone wants to now what the tested speed is of a device used for Ready Boost on your Vista system, it can be seen in the registry at:...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • Old server
    About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
