battery wont charge
i have a dell inspiron 1525 when i got it a year ago the battery didnt work... about 2 weeks ago the hdd died so i replace it with a wd blue 1tb the next day the power wire crapped out (the wire wore at the plug) but i was able to take it apart and fix it... yesterday i noticed the battery had some charge (63%) but still if i put my cursor over the icon it says connected but not charging... what would cause the battery to catch a charge after a year+ of not working to it charging then not again?????
    Dell Inspiron 1525
    4GB DDR2
    WD Blue Scorpio 1TB
    fan
    Logitech M215 wireless
    LIGHTNING FAST
Actually, this happens to me on occasion with a similar laptop. Try unplugging the power cord from the outlet and from your computer for about thirty seconds and then plug it back it back in. If it doesn't start working after doing that three times, restart your computer. That usually fixes it for me.
    Dell Inspiron 1545
    Intel Core 2 Duo T6400 @ 2.00 GHz
    DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
    Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
    1366x768
    Internal 320 GB
    Portable 320 GB used for separate storage of media, plugged into USB port as needed.
    Single built in fan
    Built in
    Touchpad, + Logitech wireless mouse (USB)
    ~150 kilobytes/sec DL
    Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
that didnt work at all
    Dell Inspiron 1525
    4GB DDR2
    WD Blue Scorpio 1TB
    fan
    LIGHTNING FAST
Only other thing I can think of is that your repair didn't fix it well enough and the cord is broken.
    Dell Inspiron 1545
    1366x768
    Internal 320 GB
    Single built in fan
    Built in
it didnt work when the cord looked new... also ive taken it apart and redid it just to check (its not a wire splice i re soldered the wires right to the plug) plus if the cord should have nothing to do with charging except that it supplys power the computer is what says charge or not
    Dell Inspiron 1525
    4GB DDR2
    WD Blue Scorpio 1TB
    fan
    LIGHTNING FAST
Ok so will you computer turn on if the battery is taken out? If it does, then your cord is fine and I'd say you need to buy a replacement battery.
    Dell Inspiron 1545
    1366x768
    Internal 320 GB
    Single built in fan
    Built in
This worked perfectly for me when I had the same problem:
Power management software in Windows Vista
Understanding battery charging issues
If the notebook battery is not charging or the notebook does not indicate that the battery is charging, the most likely scenario is that the battery itself is operating correctly, but its power management software may have become corrupt. In order to correct the problem, you will need to uninstall and reinstall the power management software by using the Device Manager. This document will explain how to uninstall and reinstall the ACPI Battery listings in Windows Vista, as well as how to obtain and install updated BIOS files, if needed to correct other battery issues.
Uninstalling and reinstalling power management software in Windows Vista
In order to correct problems with the battery's power management software, follow the steps below.
1. Click Start and type device in the search field, then select Device Manager .
2. Expand the Batteries category.
3. Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4. On the Device Manager taskbar, click Scan for hardware changes .
Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. Restart your computer. The notebook should now indicate that the battery is charging.
    HP G60-230us notebook
    3 gb
    320 gb
    broadband
The laptop battery is a finicky thing. OEM ones (originally equipped with the laptop) generally tend to be reliable, but they will start behaving in less desirable ways if left to sit for very long periods without use. They are designed to be used frequently. You can shelve them for a while, but it's a good idea not to do it with them near depletion (I've heard it generally recommended to be around 75% charged, and kept in a cool dry place). Once a battery has been strained, it can start behaving oddly like working fine for a while but then rapidly losing charge all of a sudden.
It's generally not a good idea to try repairing a laptop adapter wire, unless you're skilled in this kind of thing. It could very well be that your repair may power the laptop but not handle charging the battery simultaneously. In any case, what you should do is try to calibrate the battery. If you're not sure how to do this, here's an outline:
Laptop Battery Calibration for Windows Vista/7
1. Create Start > Control Panel and double click Power Options
2. Click Create a power plan on the left side of window
3. Select the Power Saver radio button
4. In the Plan Name field, type the name you want to call the power plan, i.e. Battery Calibration
5. Click the [Next] button.
6. Click the [Create] button.
[NOTE: At this point your new power plan is active and you can choose to change other settings in the plan, (i.e. "Put the computer to sleep" to "Never"), from the Select a power plan window that is active or just close the window and continue.]
7. Change the Critical battery action to Do Nothing by clicking Start > Run or Windows Key+R and
type powercfg -setdcvalueindex scheme_current sub_battery batactioncrit 0
8. Click on the [OK] button, and make note of the time (this will give you a base-line to know how long your battery lasts from full to exhausted with continuous use).
9. Use the laptop as normal and stop any work before the battery runs out.
[NOTE: Remember to change back to your normal power scheme once you boot the laptop.]
10. After the laptop battery is completely discharged, reconnect your power supply and turn on the laptop.
11. Once the laptop boots, login and restore your previous Battery critical action by using Control Panel > Power Options and change you plan settings for your current power scheme back to the way you had it, or use the same command in step 7 as follows:
Use the following command for Setting you critical battery action to Sleep
powercfg -setdcvalueindex scheme_current sub_battery batactioncrit 1
Use the following command for Setting you critical battery action to Hibernate
powercfg -setdcvalueindex scheme_current sub_battery batactioncrit 2
Use the following command for Setting you critical battery action to Shut down
powercfg -setdcvalueindex scheme_current sub_battery batactioncrit 3
CAUTION: This setting is only for running the battery completely down. It may cause loss of data and you need to make sure you are not edit/saving data when the battery runs down and the system turns off. This setting will not allow the computer to shutdown, hibernate or sleep. It will just turn off.
It's a good idea to run the battery calibration at least every 3-4 months, if you leave your laptop plugged in most of the time. Otherwise, at least every 6 months. Laptop batteries tend to start losing their charge holding capability after one year, and usually wear out after 2-3 years with regular use. Lithium-ion batteries do have a limited shelf life as well, and storing them after they've been put to use won't extend their lifespan very much.
    HP Pavillion dv5t
    Intel Core Duo 2.53GHz
    4Gb
    NVidia GeForce 9600M GT 512Mb
    1280x800 32bit
    Seagate Momentus XT 500Gb
    Hitachi Travelstar HTS543225L9A300 250Gb
    Microsoft 4000
