hi i have a problem
  1. #1
    Newbie
    windows vista 32-bit sp1
    Local Time: 05:14 PM
    hi i have a problem
    hi guy new to the forum so looking for some help please!!
    my computer will not start in normal, i can start it in safe mode but when i select start vista it just restarts itsself and i have ran system repair about 10 times and still no luck does anyone have any advice on what i can do thank you or if you need anymore info it is windows vista aswell guys thanks
    ps: and windows update wont open i click it and nothing happens aswell thanks
    pss:just to rub it in more i dont have any restore points either.
  2. #2
    Senior Member
    Ultimate x64, home Prem 64
    Local Time: 07:14 PM
    canada
    Re: hi i have a problem
    It seems like its either an update or driver issue. Someone else on here will post how to clean boot and then selective restarts to narrow the issue down.
    Basically, in my opinion, something got borked, so when your booting into normal start its hanging, but in safe mode, it doesnt load that driver or software.
    I'm not great in this part of vista, so i'll let someone else continue.
  3. #3
    Newbie
      Thread Starter
    I have just installed a new windows but now cannot connect to the Internet will I have to manually plug the Ethernet cable in or can I get the driver from my windows l.old file to replace the new one an which one and were is it please thanks for your reply mate!!!
  4. #4
    richc46's Avatar
    BSOD Squad
    Fairfield County, CT
    Windows 7 SP1 x64
    usa us connecticut
    Welcome
    Patonb is correct. If you boot ok in safe mode,its a software issue. Now the difficut part, what software. Maybe a clean boot will help us diagnose.
    Troubleshoot Application Conflicts by Performing a Clean Startup - Windows 7 Forums
    EDIT: You posted at the same time as me and now the problem is different. With another computer, you can download any necessary drivers to a finger drive and then transfer to your problem computer.
  5. #5
    Newbie
      Thread Starter
    Hi rich yeh just done a install and it now works!!! Kept my old windows file though but like I said in my last post I cannot connect to networks now maybe because I don't have the driver can I get that driver from my old windows file??
    Ps:I only have this one laptop and a iPhone haha so if I just connect it through the Ethernet it should work shouldn't it???
  6. #6
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    May I make a suggestion, before you proceed too far? Make a clean install, everything may work after the install. If you still cannot connect to the internet, get the driver using the method that I suggested.
    For EVEYONE a clean install is the way to go. You did what is called an upgrade install.
    Clean Install From Upgrade Vista
  7. #7
    Senior Member
    canada
    Unfortunately, you may not still get on the network, but if you used a recovery disk to redo windows, most likely the reason you csan't get on the net is due to you no longer having the passwords saved.
    Thats easy to fix by clicking on the computer shaped symbol by the time in the lower right corner.
    You can find If you need drivers by going to the device manager and looking for red X or yellow ?
  8. #8
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    I would still do a clean install, it is always the best. If you still do not have internet, follow Patonb, but do a clean install.
  9. #9
    Newbie
      Thread Starter
    All sorted now thanks guys thank you do much for your help I there anywhere I can donate??? Close the thread please thanks once again
  10. #10
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    You have already donated with your thanks and appreciation. Good luck.
Page 1 of 2 12 LastLast
hi i have a problem problems?
the problem with ndis.sys Blue Screen of Death problem solved? liketofindoutwhy Vista General 6 24 May 2009
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Rainald Taesler Vista mail 14 17 May 2009
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Jim Hansen Vista General 3 16 Dec 2007
Generic McAfee Problem Message in Vista Problem Reports cyberbuff53 Vista performance & maintenance 0 01 Dec 2007
Vista Upgrade Problem - Windows Explorer Loop problem Steve S Vista installation & setup 0 27 Jun 2006
