Please help!!! Display and Internet problems!!!
  1. #1
    Newbie
    Vista
    Local Time: 04:30 PM
    Hi. I am new to this group and have been having some crazy stuff go on with my Samsung laptop the past few days. My husband bought this laptop from a friend of ours to use for school. It has always said her name under the files. Monday we tried to change it by following instructions on-line. However, ever since doing that, it looks like somehow we completely restored the entire computer. All of his school word documents had been moved the trash bin, although I had saved his previous theme, it wasn't there after all of this took place and also Internet Explorer is not working not. It will say, "Internet Explorer has stopped working..." while trying to go to a website. Also this morning I have noticed now, whenever you try to change anything, like your homepage on the internet or anything in the control panel, the boxes that pop up (where you can check/un-check things, etc.) are all blank. You cannot see any words or the "OK" "Cancel" buttons. The only things visible are the check marks on things that are checked. I am getting so frustrated with this and my husband needs this laptop for his schoolwork. I have included some screenshots of what I mean. If anyone could please help me, I would GREATLY appreciate it!!! TIA!!
  2. #2
    richc46's Avatar
    BSOD Squad
    Fairfield County, CT
    Windows 7 SP1 x64
    usa us connecticut
    Re: Please help!!! Display and Internet problems!!!
    Apparently you changed something that you should have left alone. Hopefully there are some system restore points and they will help. Try a system restore from before the problem
    System Restore - How to
    After seeing the screen shots, I hope that you can get to restore.
  3. #3
    Newbie
    Vista
      Thread Starter
    Well, that is also a problem because when I pull that up the screen is empty like the others were. I cannot see anything there.
  4. #4
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    Do you want to try for a factory restoration? It will be like the day that it was taken home, by the first owner. You will lose your stuff. Have stuff you want to save first?
    If you want to go for the restoration, give me make and model of computer.
  5. #5
    Newbie
    Vista
      Thread Starter
    At this point I don't know what else to do. My husband needs Internet Explorer and everything to run properly. The box says Samsung R480....does that help?
  6. #6
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    Go to the section complete restore
    How To Use Samsung Recovery Solution 4 my samsung=
    You will lose all your stuff.
  7. #7
    Newbie
    Vista
      Thread Starter
    OK, I will do this now, I hope it works
  8. #8
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    I hope so too. Good luck
  9. #9
    Newbie
    Vista
      Thread Starter
    That worked. Thank you!!!!
  10. #10
    richc46's Avatar
    BSOD Squad
    Windows 7 SP1 x64
    usa us connecticut
    Im really glad that we helped solve your problem. Come back any time.
Internet Explorer cannot display the webpage innocentboy Browsers & Mail 29 17 Dec 2010
Internet Explorer cant display webpage Libra Browsers & Mail 8 02 Feb 2009
Internet Explorer cannot display the webpage wkawai235@aol.com Vista General 3 11 Mar 2008
ie7 - Internet Explorer cannot display the webpage roger Vista General 6 28 Aug 2007
problems with wireless ebay signing in "Internet Explorer cannot display the web mrchev Vista networking & sharing 5 22 Apr 2007
