Help! Cutting and Pasting files -- PROBLEM!!!
Avrohom
Help!
I was in the middle of moving (cutting and pasting) over 3 GB of files to burn to a DVD. The computer complained in the middle of not enough room.
But now I can't find the files that were in the middle of being moved!!! Is there any way I can access them? :cry:
Avrohom
When I saw there wasn't enough room on the DVD, I inserted a new DVD. That is when I didn't see the missing files. But when I reinserted the first DVD -- I saw all my files again -- ready to be burned.
I find this confusing: for one DVD the computer shows the files ready to be burned. But for a different DVD -- these files are not shown.:sarc:
Very strange, not sure what explanation to offer. You could always have located them by doing a Start/Search if you had a name.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    1 external eSATA LaCie 3TB
    (Non-RAID)
    Unique
    1gb/s up and down
In addition, if you hadn't restarted your machine the files should still be present in RAM so you could just re-paste them to a storage location with sufficient space.
Not an issue that I have personally run into myself, I always copy and then manually delete when moving files just to be safe ;)
Josh :)
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Shadow Explorer can recover files from restore points and is free
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
