Notebook will not reconize Sony Memory Stick PRO Duo all of sudden
brketo
I have Gateway P6860 FX notebook with Vista Home Premiuim..It has worked perfectly for last three year with Sony Memory Stick PRO Duo, then all of sudden it would work off and on, now wont work at all, says can not reconize device. transfering pictures to a file
Have you tried another computer?
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
You may need to update the usb driver but it could be the plug and socket moving about when you are copying files and loosing contact momentarily. My sound card does that. unplug and plug it in again normally works
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
