| Vista Home Premium 32bit | Will "Call of Duty 4" work well on my laptop? Call of Duty 4: Modern Warfare Minimum requirements: CPU: Intel ® Pentium ® 4 2.4 GHz or AMD ® Athlon ™ 64 2800 + processor or any 1.8Ghz Dual Core Processor or better supported RAM: 512MB RAM (768MB for Windows Vista) Harddrive: 8GB of free hard drive space Video card (generic): NVIDIA ® Geforce ™ 6600 or better or ATI Radeon ® ® 9800Pro or better Laptop Specifications: HP Pavilion DV2860EE CPU: Intel® Centrino® processor technology, Intel® Core™ 2 Duo processor T9300, 2.50 GHz , Level 2 cache 6 MB. RAM: 4096MB RAM Harddrive: 320 GB Video adapter: NVIDIA® GeForce™ 8400M GS Video RAM: Up to 1407 MB Total Available Graphics Memory with 128 MB dedicated Have I meet the requirements to be able to play Call of Duty 4: Modern Warfare? |
| vista ultamate 64bit | Re: Will "Call of Duty 4" work well on my laptop? In my opinion it will run just fine, so long as you don't try to crank the graphics up you should be able to play comfortably |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: Will "Call of Duty 4" work well on my laptop? Rip is right - your laptop should have very little in the way of issues playing that game - and the way it looks, if the 6600 is the min spec required, then you should get a decent playing experience. If those are the *recommended* specs then you should have a pretty good experience. |
| Vista Ultimate X64 SP2 | Re: Will "Call of Duty 4" work well on my laptop? YES It will run on the NVIDIA® GeForce™ 8400M GS Class 3 Low-Midrange Graphics Cards - Lower end of Graphics Cards for users who want to play games. New games should run on these cards, but only with decreased details and mediocre resolution. Last edited by rive0108; 06-26-2008 at 06:57 AM.. |
| Vista Home Premium 32bit | Re: Will "Call of Duty 4" work well on my laptop? Will it run on my HP Pavilion dv9925nr Notebook PC ? 4096mb DDR2 SDRAM nVidia GeForce 7150M (if more info is needed then i can probly provide it) |
| | #6 (permalink) |
| Vista Home Premium 64bit | Re: Will "Call of Duty 4" work well on my laptop? Goto: Can You RUN It? It's pretty good web utility to indicate what you can and can't run. |
| | #7 (permalink) |
| Windows Vista Home Premium 32 bit | Re: Will "Call of Duty 4" work well on my laptop? I've got a toshiba satellite laptop running on vista with the following specfications: Processor: Intel Core 2 Duo CPU T7100 @ 1.80GHz Memory (RAM): 2.00 GB System Type: 32-bit Operating System Graphics Card: ATI Mobility Radeon HD 2600 http://ati.amd.com/products/radeonhd2600/specs.html above is a link to some more info on my graphics card just wanted to know if my laptop would be able to run Call Of Duty 4: Modern Warfare, or if i needed to upgrade anything... any help would be great...thanks |
| | #8 (permalink) |
| Vista Home Premium 64bit | Re: Will "Call of Duty 4" work well on my laptop? Minimum System Requirements Required (minimum) Specs CPU: Intel(R) Pentium(R) 4 2.4 GHz or AMD(R) Athlon(TM) 64 2800+ processor or any 1.8Ghz Dual Core Processor or better supported RAM: 512MB RAM (768MB for Windows Vista) Hard Drive: 8GB of free space Video card: NVIDIA(R) Geforce(TM) 6600 or better or ATI(R) Radeon(R) 9800 Pro or better Recommended Specs CPU: 2.4 GHz dual core or better RAM: 1G for XP; 2G for Vista Hard Drive: 8GB of free space Video card: 3.0 Shader Support recommended. Nvidia Geforce 7800 or better or ATI Radeon X1800 or better |
| | #9 (permalink) |
| Vista Home Premium 64bit | Re: Will "Call of Duty 4" work well on my laptop? Call of Duty 4: Modern Warfare Minimum requirements: CPU: Intel ® Pentium ® 4 2.4 GHz or AMD ® Athlon ™ 64 2800 + processor or any 1.8Ghz Dual Core Processor or better supported RAM: 512MB RAM (768MB for Windows Vista) Harddrive: 8GB of free hard drive space Video card (generic): NVIDIA ® Geforce ™ 6600 or better or ATI Radeon ® ® 9800Pro or better Laptop Specifications: HP Pavilion DV2860EE CPU: Intel® Centrino® processor technology, Intel® Core™ 2 Duo processor T9300, 2.50 GHz , Level 2 cache 6 MB. RAM: 4096MB RAM Harddrive: 320 GB Video adapter: NVIDIA® GeForce™ 8400M GS Video RAM: Up to 1407 MB Total Available Graphics Memory with 128 MB dedicated Have I meet the requirements to be able to play Call of Duty 4: Modern Warfare? |
| | #10 (permalink) |
| Vista x64 Ultimate Sp1 (Primary) dual booted with XPsp3 | Re: Will "Call of Duty 4" work well on my laptop? Everything suggest yes, until you look at the video card....the 8400GS is pretty poor unless you like low res or bad FPS but hopefully the rest of the rig will pull it up to a playable level without too much compromise in quality |
| Call of Duty 4 will not work on my comp! | Gaming | |||
| "Start Video Call" Won't Work | Live Messenger | |||
| Error on return from function call in ASP.NET "Operation is not supported on this platform." | .NET General | |||
| CoD 4 is "Preparing to launch Call of Duty 4: Modern Warfare..." FOREVER! | Gaming | |||
