Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - 8500gt and 4gb memory problem..
Old 08-04-2008   #1 (permalink)
Vista Ultimate 32bit/ Mac OS X 10.5.5
whenever i have 4gb of memory installed into my mobo with an 8500gt 512mb video card in my computer doesn't not want to start..
but with just 1 stick of 2gb memory in everything starts up fine..
Intel D915GUX motherboard
Kingston pc6400 2x2gb memory
nVidia 8500gt 512mb graphics
Old 08-05-2008   #2 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Re: 8500gt and 4gb memory problem..
Have you disabled your onboard graphics?
Old 08-06-2008   #3 (permalink)
yes i did.
now i have an ATI radeon x600 series card installed and it works just fine.
could it be an incompatibility with nVidia and intel boards?
Old 08-06-2008   #4 (permalink)
Or it might be that card is too powerful for your PSU....
Your stats in your sig aren't thorough enough :P ....what is the PSU?
Old 08-06-2008   #5 (permalink)
oh sorry the stats in my sig are way outdated.
the power supply that i have right now is 480w watt
but the thing i don't get is that how come when only 1 stick of 2gb ram is installed everything works out fine but when 2 sticks of 2gb ram is installed it doesn't want to boot up.
Old 08-06-2008   #6 (permalink)
Vista Ultimate x64 SP1
Watts don't tell us anything; we need to know the amperage. What's the make and model number of your PSU?
Old 08-06-2008   #7 (permalink)
Vista x64 Ultimate
PC6400 is 800 MHz RAM. Try two sticks of 533 MHz RAM and see if that helps. Enable the memory hole/remapping on the board. Upgrade the BIOS. Post your complete specs and power supply specs. I would say its wrong ram configuration.
Old 08-06-2008   #8 (permalink)
According to the motherboard specs D915GUX, Features it can run that RAM just fine.
Old 08-07-2008   #9 (permalink)
Quote  Quote: Originally Posted by SCSIraidGURU View Post
oh my mistake i am using 533mhz ram.
and the bios on this motherboard is a gateway OEM bios and for some reason it won't let me replace it with the real intel bios
Quote  Quote: Originally Posted by johngalt View Post
and yes it runs it just fine.
right now i'm running both sticks with the ati radeon x600 video card and everything is just fine.
but if it was my power supply not being enough to power the 8500 then wouldn't it not boot up with just one 2gb stick in?
nVidia GeForce 8500GT Dual Monitor Help Graphic cards
Overclocking 8500gt Graphic cards
low memory problem Vista General
Possible to use onboard graphics plus 8500gt Graphic cards
problem with memory (graphics shared memory) Vista General
