Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - Geforce 8400M GS driver problems
Old 09-22-2008   #1 (permalink)
Vista Ultimate SP1 32bit
I have had a couple of taskbar messages now to tell me the GPU has crashed and fixed itself, previously i had thought it was because i was running 3D games in a window, the problem shows itself as random colour blocks on the desktop and then the whole display flashing, like the computer is about to go into a UAC prompt, culminating with the message on the taskbar regarding the GPU. but now it is happening just with DreamScene running, so im all excited 'cause woo hoo, fiinally Vista is doing something other than just working right anytime all the time. I am using Vista Ultimate with SP1 32bit on my dv6519tx laptop, the laptop had Vista home premium originally, and I have the latest Nvidia driver from HP which is driver 7.15.11.7432. I have downloaded the latest Nvidia driver from their website, but as this isnt specifically a mobile 'M' driver, i havent yet installed it. Has this happened to anyone else?
Old 09-22-2008   #2 (permalink)
Re: Geforce 8400M GS driver problems
well using an nVision modded inf i installed driver version 7.15.11.7637, will see if this makes things more stable.
Old 09-23-2008   #3 (permalink)
Vista Ultimate x64
Find your driver on the nvidia website and check whether it matches the HP one..
Amplid
Old 10-01-2008   #4 (permalink)
well the modded inf drivers gave me my first BSOD in Vista. (I thought people who said Vista had BSOD's were making it up!), so i went back to the Hp drivers. Have seen the strange block artifacts one time since, and it seems to be linked to dreamscene playing.
Old 10-01-2008   #5 (permalink)
Vista Ultimate x64
I checked on the nvidia webpage, but haven't found any drivers for your card... Try sending them an email and ask where best to download the driver for your 8400M GS. That should (I say SHOULD) take care of any display problems...
Amplid
Old 10-01-2008   #6 (permalink)
vista home premium SP1 32bit
just to let you know, it might be worth having a look at microsoft update, i have only just now installed an update for the 8400GS, it was released today. they might have made all the latest drivers available throught ms update....
Old 10-19-2008   #7 (permalink)
vista ultimate 64bit
i have problem with this drivers too.
i can't find drivers that fit on vista 64bit.
can someone give link to dowload working geforce 8400M gs drivers ?
Old 10-19-2008   #8 (permalink)
Vista Ultimate x64
Videodriver voor NVIDIA GeForce 8400M/8600M GS * That's the hp one. Haven't found another so far... As I said, send email to nvidia and ask them.
Amplid
Old 11-02-2008   #9 (permalink)
Vista Home premium 32bit
I have same problem.First of all,I want to excuse myself for my English.
And second thing is that, 4 days ago i've tried to change some files in original Hp driver (latest) I copyed all the files from driver which i've downloaded from nvidia.com and it was great.Driver worked.But yesterday i needed to reinstall my Vista.after installing i've tried to do the same with drivers for video card,but it never happened.I've still have that Hp.com version.People...what to do?Please answer here or email me at alimcikR@gmail.com Thank you
Old 11-02-2008   #10 (permalink)
Vista Ultimate x64
Welcome to the forums,
So, before reinstalling vista, you had proper drivers and the graphics card was working fine, or did you have BSOD's as well?? After reinstalling, you can't find the proper drivers anymore... Is that it?
Amplid
Cant get a driver for geforce 6200 Graphic cards
Question about Geforce 8400M-GS Graphic cards
Nvidia GeForce 6200 driver problems Vista General
nvidia geforce 6800 xt driver problems Vista hardware & devices
nvidia GeForce FX 5200 card driver incompatible with GeForce 7600GS ?? - 4 monitors Vista installation & setup
