| vista Home Premium x64 | Problem with geforce 8800 GT Hi My graphics keeps shutting down the pc dosent freeze or crash the screen just keeps going black. This happens about 5mins in. I've got the new updated driver for it i've also sent back the card and got a replacement still have the same problem. Please can someone help me or i might have to go back to XP which i dont want to do. Throbinson |
| Vista Ultimatex64 Windows 7 build 7100 | Re: Problem with geforce 8800 GT |
| Vista home premium 64 bit | Re: Problem with geforce 8800 GT Have you tried safe mode? Have you booted to the bios to ensure it is not hardware related? |
| vista Home Premium x64 | Re: Problem with geforce 8800 GT it all works fine in safe mode, i thinK it could be a conflict with the on board graphics carn't find anywhere in the bios to disable the on board graphics |
| Vista home premium 64 bit | Re: Problem with geforce 8800 GT It sounds like a driver error. Uninstall all the software for the device then uninstall the graphics card from the device driver. When you reboot it will reinstall the graphics card. |
| | #6 (permalink) |
| Vista x64 + Windows 7 x64 (Ultimate) | Re: Problem with geforce 8800 GT What mobo you have that you can't get to disable your onboard card? |
| | #7 (permalink) |
| vista Home Premium x64 | Re: Problem with geforce 8800 GT What mobo you have that you can't get to disable your onboard card? |
| | #8 (permalink) |
| vista Home Premium x64 | Re: Problem with geforce 8800 GT |
| | #9 (permalink) |
| Vista x64 + Windows 7 x64 (Ultimate) | Re: Problem with geforce 8800 GT Asus is a recognizable Brand, has/makes really good boards, I doubt very much they would make or use a Bios and not give you capabilities of Enableing/Disableing your Onboard Audio and Video since they pretty much know that 99% of the people who buy their boards will toss the onboard audio/video and replace it with a PCI/PCIe card. If you have your manual, open it up and do some reading, I am sure is there, probably hidden under something else that you don't realize. I can't say with 100% certainty but I am almost 90% sure there is a way to Disable it. Being said that, I think that it is clear now that your problem is the conflict with both cards and both different drivers... the more PC gurus here will know more than I do though. |
| | #10 (permalink) |
| vista Home Premium x64 | Re: Problem with geforce 8800 GT Asus is a recognizable Brand, has/makes really good boards, I doubt very much they would make or use a Bios and not give you capabilities of Enableing/Disableing your Onboard Audio and Video since they pretty much know that 99% of the people who buy their boards will toss the onboard audio/video and replace it with a PCI/PCIe card. If you have your manual, open it up and do some reading, I am sure is there, probably hidden under something else that you don't realize. I can't say with 100% certainty but I am almost 90% sure there is a way to Disable it. Being said that, I think that it is clear now that your problem is the conflict with both cards and both different drivers... the more PC gurus here will know more than I do though. |
| NVIDIA Geforce 8800 GTX | Graphic cards | |||
| Can't install with GeForce 8800 GTS? | Vista installation & setup | |||
| nvdia geforce 8800 GTS | Vista installation & setup | |||
| Any DirectX 10 samples to test my GeForce 8800??? | Vista General | |||
| Anyone with a GeForce 8800 GTS under Vista 64-bit? | Vista hardware & devices | |||
