well all i am really trying to do is lower the temps on the card it is at its stock setting i just don't like it at 50c all the time i'd like to bring down to at least 45
try speedfan, by almico, i use that to control my fan speeds. Download SpeedFan - Access temperature sensor in your computer
still not what i need........ i guess a new case would help but i don't want to send anymore money right now......
you're absolutely sure that there isn't an option for you in catalyst control center?
yea its odd....... but i got a new case so i'm good
i think that acer locked all overclocking related things so i don't
until i get my new mobo and cpu i can't overclock at all..... o well![]()
All Acer (and the others) do is use a custom bios that has the options that would allow for overclocking hidden. They also had nothing to do with the video card.
One thing I forgot to ask previously, the fan on your card have two wires or three? If it is only a two wire fan then there is no way to control the fan speeds using software. Then the only way to do that would be to use a modded bios (the video card, not the motherboard), downloaded or modded yourself,
Guide to ATI BIOS modding and flashing
yea it is 2 wire..... hm and doesn't matter i plan to upgrade soon anyway...... at least i hope to![]()
| Similar Threads | ||||
| Control C and control v shortcuts aren't working | rob12345 | General Discussion | 3 | 27 Oct 2009 |
| How can I control the size of icons in Control Panel? | MaryL | Vista General | 6 | 19 Jul 2008 |
| Exposing contained control properties from within a custom control | Martin Robins | Avalon | 1 | 10 Apr 2008 |
| Exposing contained control properties from within a custom control | Martin Robins | Avalon | 0 | 10 Apr 2008 |
| How do I use Custom Control Properties in Control Templates? | Joerg Engel | Avalon | 1 | 24 Mar 2006 |
