Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - Need help with graphic, card
Old 03-10-2009   #1 (permalink)
Vista Home Premium 32bit.
hello I have a gateway GT5672E it has intel 82945G on the mb, with 64mb dedicated system memory and 192 shared system memory with directx 9.0 or better version.I have 2.0gb ram in my system with 2 processor cores 32 bit os.,mb has 1=pci express x 16 connector,1 pci expressx1 &1=pci conventional with a 300 watt power supply what do u think of a BFG NVIDIA GeForce 8400 GS 512MB DDR2 PCI Express Graphics Card
i never do games only pictures and videos I can get this at bestbuys for $69.00
thank u in advance
Old 03-10-2009   #2 (permalink)
Vista Home Premium 32bit and Ubuntu 9.10 32bit
Re: Need help with graphic, card
hmm..... that should be ok i guess......
skunksmash, mr needs, everlong..... what do you guys think?
Old 03-10-2009   #3 (permalink)
Vista Home Premium 64bit
Your system is fine for SD video...but it will push it for High Definition video. Especially if it's H.264 variety.
My understanding is Graphics cards don't have a big play in Stills (photos) & video as the rendering (2D) is done by the CPU.
By all means buy the Graphics card as it's a good price but if funds are very limited I'd go for more RAM. But that's just me.
Old 03-10-2009   #4 (permalink)
Vista x64 + Windows 7 x64 (Ultimate)
Quote  Quote: Originally Posted by Clevo View Post
+ 1
if you have a Tiger direct in your area, they have the same card for 49.99
BFG GeForce 8400 GS Video Card - 512MB DDR2, PCI-Express 2.0, (Dual Link) DVI. VGA, HDTV BFGE84512GS64E at TigerDirect.com
I don't believe it needs power direct from the psu so you'll be alright.
Good Luck
Old 03-10-2009   #5 (permalink)
unless of course you would want to go with ati.......
a HD3650 is only about $80 and will be more than powerful enough for anything you do
or a HD3450 for about $50.........
Old 03-10-2009   #6 (permalink)
Vista Ultimate x64
no 3450, get the 3650.. and it's not $80, it's $49
Newegg.com - SAPPHIRE 100236L Radeon HD 3650 512MB 128-bit GDDR2 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Desktop Graphics / Video Cards
Id say instead of getting a 8400. get the 8600GT. or GTS.
or even better. get a 3850, it could run with a 300w psu probably.
Old 03-10-2009   #7 (permalink)
o.... i want two on crossfire....
Graphic Card ? Graphic cards
Graphic card Virtual PC
need help with my graphic card Graphic cards
Video card? Graphic card? Vista General
Graphic Card Vista General
