Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - Fan speed control
Old 03-15-2009   #1 (permalink)
Vista Home Premium x64
Fan speed control
Has anyone else noticed that the GPU fan speed control is not functioning with Vista 64 and the Radeon 3870x2? I am running Riva tuner to make the fan operate manually but I once had the option with Vista 64 and not flashing the card either.
Old 03-15-2009   #2 (permalink)
Vista Ultimate x64 SP1
Re: Fan speed control
Tried using the fan control option in the Catalyst Control Center?
Old 03-15-2009   #3 (permalink)
I would if it was there. I have read there is some sort of a problem with that function when running the 3870x2 card. The card is supposed to be flashed so that it can work but I do not wish risking harming the card by flashing so I use rivaturner.
Old 03-15-2009   #4 (permalink)
Here is the way CCT works with the 3870X2 card
Old 03-16-2009   #5 (permalink)
Yeah, I did some research and see the 3870x2 doesn't have the fan control option. Don't know what else to say; I've never used Riva Tuner so I have no suggestions there either. I don't even use the CCC's fan control with my 4850, which incidentally, replaced my 3870.
No other suggestions here.
Good luck.
Old 03-16-2009   #6 (permalink)
Vista Home Premium 32bit
Hey
I installed SmartDoctor with came with my 4870.
It has fan speed control.. My 4870's CCC doesnt have
fan speed control either..
Hope this helps
Old 03-16-2009   #7 (permalink)
Hey
Hope this helps
Old 03-16-2009   #8 (permalink)
Vista Ultimate SP2 x64 Windows 7 Ultimate x64 TECHNET
I have no fan control option either.
Old 03-16-2009   #9 (permalink)
Vista Home Premium 64bit SP2
Riva Tuner is a lighweight app , ive been using it for years for custom fan profiles , stick with it mate , its less hassle
Old 03-16-2009   #10 (permalink)
Quote  Quote: Originally Posted by Pokerking View Post
Hey
Hope this helps
Quote  Quote: Originally Posted by Airbot View Post
You need to have an ATI 4800 series card to have the fan control option under Catalyst Control Center. I have a VisionTek 4850 and it has the fan control option under the Catalyst Control Center (9.2); has been there since the 8.10.
New Catalyst 8.10 Drivers Bring Fan Speed Control - Tom's Hardware
Catalyst Control Center™ Fan speed control
Also, in order to access the fan control option, you'll need to "Unlock" Auto Tune.
Does WSR have a speed versus accuracy control like Dragon does? Vista General
I like the CPU speed control in Power-->Advaanced settings, with p Vista General
Fan Speed Control and Overclocking Overclocking & Cooling
Again: MS Mouse Pointer Speed Control - but WIN XP Prof. Vista General
MS Mouse Pointer Speed Control Vista General
