Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - Weird Dual Monitor Power Problem
Old 06-09-2009   #1 (permalink)
Vista Home Premium 64 bit
I am experiencing a strange power problem with my monitors. I have two, each hooked up to a Radeon HD 800 series video card with dual DVI connectors.
The problem is this: When I have my computer working as normal, if I switch off my secondary monitor, and then switch it back on, my primary monitor's display garbles and goes out for a second until my secondary monitor is back on. Also, anything that was displaying on my secondary monitor does not refresh and I can not access those programs.
Does anyone know what is wrong and how to fix this?
Thanks,
Michael R
Old 06-09-2009   #2 (permalink)
Vista Ultimate x64 SP2
Re: Weird Dual Monitor Power Problem
Have you try to update ATI drivers?
Old 06-23-2009   #3 (permalink)
Yes all of the latest drivers are installed.
- Michael R
Old 06-23-2009   #4 (permalink)
XP x64 pro/Vista 32bit/Vista x64/7/leopard
when you go to adjust your display settings does it list your monitors by name, or does it list them as PnP monitor? are you using catalyst control to make your settings or are you using vista display settings?
Old 06-24-2009   #5 (permalink)
My monitors are listed by name. Using Catalyst and Vista display settings are identical and each work exactly the same.
- Michael R
Solved Dual monitor problem Graphic cards
Weird problem after dual boot setup General Discussion
Dual Monitor Problem Vista General
Dual Monitor Problem Vista hardware & devices
BUG: Problem with Holding Power Option for Monitor sleep Vista General
