Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - major problem with 7950 gx2 and vista ult.
Old 06-19-2009   #1 (permalink)
Vista Ultimate x64
Hey everyone,
I am having a bit of a problem with my Nvidia Geforce 7950 gx2, everytime I download the new update it stalls and then goes to a black screen then boots a blue error that has nvlddmkm.sys....I can't figure out what to do. Tried everything and still need some help.
I am running
- Vista Ult. x64
- ASUS A8N-SLi Prem
- Nvidia 7950 gx2
- AMD 64 X2 Dual Core Proc 4200
Thanks, and hopefully someone can help me out a little.
Old 06-19-2009   #2 (permalink)
Vista Home Premium 64bit SP2
Re: major problem with 7950 gx2 and vista ult.
what new update? windows?
just uninstall yuor gpu drivers , reboot so vista installs its generic ones then try again , it might help
if your problem is your trying to install new Nvidia drivers then just give up , that card is notorious for being a dog , the driver supporet was always shocking for it , so pick some drivers that work and stick with em
Old 06-19-2009   #3 (permalink)
Vista Ultimate x64
Thanks for the advice, and I should have said that the new updates arent working at all. Do you know where I could find a driver that would work for it? If so that would be great. Oh and how do I go about cleaning up the Gpu, I have little knowledge in that.
Old 06-19-2009   #4 (permalink)
sorry mate im not quite undestanding what you need
you mean you cant install any drivers for your graphics card?
and do you want help uninstalling the old drivers?
Old 06-19-2009   #5 (permalink)
Vista Ultimate x64
Well here the thing, it isn't installed, and when I go to install it constantly stalls in the middle of the install and then goes blank. I have deleted all of the nvlddmkm.sys that were causing a problem. Now my computer won't recognize the card, and I can't figure out why it won't install and the update wont work at all.
Old 06-19-2009   #6 (permalink)
please give me a link to where your getting the drivers from and download and install this
Guru3D - Driver Sweeper (Setup) download from Guru3D.com
the instructions on how to use it (in safe mode AFTER uninstalling current drivers and you would select NVIDIA DISPLAY ONLY) are on the download page
Old 06-19-2009   #7 (permalink)
Vista Ultimate x64
I just go to Nvidia's website for the download, I go to download drivers and then put in my card info and what system I am running it with. It gives me a 186.18 WHQL download...but it never works and it screws up my computer.
Old 06-19-2009   #8 (permalink)
ah i see , just checking
so what drivers did yuo use previously? can you use them again?
can you also try uninsalling your drivers booting into safemode and using driver sweeper (it cleans out all the remnants of drivers left behind by the uninstall) then boot into windows and try installing again
Old 06-21-2009   #9 (permalink)
Vista Ultimate x64
Alright I downloaded Driver Sweeper, and I cleaned out all of my old Nvidia files. Now I am instaling the geforce 109.15 Driver and I am hoping that helps. If that doesnt work what other options do I have?
7950 Problem Graphic cards
Vista POP3 Major Problem - Help MS Vista mail
Vista POP3 Major Problem - Help MS Vista General
Re: Vista POP3 Major Problem - Help MS Vista mail
problem with Geforce 7950 GX2 Vista installation & setup
