Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - Standard VGA Adaptor Problems
Old 08-16-2009   #1 (permalink)
Vista Home Premium 32 bit
I recently upgraded my graphics card from a Radeon 9600 to 3650 and that is where I struck problems.
The standard VGA adaptor isn't working or became corrupt and when I installed the
Radeon driver, the system froze after a short while.
I have tried deleting adaptor, but that also removes "Display Adaptors" from the
Device Manager, so even if I install the 3650 driver, it won't appear as installed.
I have tried doing a clean install of Vista but the same thing occurs. On the other hand
I have no problem with Windows 7 RC1 where everything works perfectly.
What purpose does the VGA serve anyway since I still have a display without it working?
Old 08-17-2009   #2 (permalink)
Windows 7 Ultimate x64
Have you connected the graphics card properly on the motherboard?
Old 08-17-2009   #3 (permalink)
Yes, otherwise it wouldn't work on Window 7. (Dual boot)
Old 08-18-2009   #4 (permalink)
Vista Home Premium x64
Quote  Quote: Originally Posted by RogCliff View Post
it is important to have you graphics driver installed, the driver is optimised for the user, it gives a cleaner picture at a higher resolution without causing much slowdown, the standard VGA adaptor driver cannot do this, it is generic...
but it is ok to delete the standard VGA graphics adaptor from device manager, you want to do that so you can install the windows driver for your graphics card... since you have already attempted to install the drivers before. just go ahead and delete it and then click on the spyglass to locate the hardware and re-install automatically
Old 08-19-2009   #5 (permalink)
It's impossible to delete the VGA adaptor as once you do, you then have to re-boot then Vista re-installs it again.
Also, I have tried installing the Radeon driver after deleting VGA and it goes through the motions of installing but that is all.
I have heard somewhere, that you have to have the VGA in place before you can install any other driver. Unfortunately, either VGA driver is faulty or there is something stopping it installing properly. When I install the Radeon over this, that is when I strike problems.
As I pointed out, a clean installation of Vista doesn't change anything.
Old 08-19-2009   #6 (permalink)
ok, looks like a few files might be corrupt on your copy of vista then, i have attached the 32bit version of the standard vga graphics adaptor drivers, unzip and put them in a folder thats easy to find, then open up the device manager and update driver software on the standard vga graphics driver and click on browse, point it to the folder the drivers are in and try reinstalling your graphics card again after restart.
(if it doesnt allow you to do this, then copy the drivers into c:\windows\system32\drivers, uninstall the vga adaptor and then restart)
Old 08-20-2009   #7 (permalink)
Hi MrNeeds,
Thanks for the driver but I was unable to update via the Device Manager as it said
the driver didn't need updating.
I tried deleting the old driver but even with admin rights, it wouldn't let me do it.
What's Microsoft's problem?
Any more solutions you can think of?
Old 08-20-2009   #8 (permalink)
When you install the driver choose the option to browse to the driver files then choose the files provided by MrNeeds.
Old 08-20-2009   #9 (permalink)
I did exactly that but doesn't want to know.
Old 08-20-2009   #10 (permalink)
Know what?
Standard and Standard without Hyper-V Virtual PC
standard user loging problems Vista account administration
Standard output and standard error merging to a log file PowerShell
Redirection of standard out and standard error PowerShell
Standard user has problems running Flash player Vista security
