how do i know hat to look for if your not telling me... :/
because im plugged into it and my screen is running off of it!!!
but in 800x600 - no advanced settings etc.
1st thing i would do is uninstall that pci-e device then reboot, before windows loads id enter bios, normally by hitting DEL and check all the settings I.e pci-e enabled ect and also if you have on-board graphics you will need to disable it, save, exit and restart, all going well you should see a new device found bubble in the bottom right hand corner..... hope this helps you, Good luck
thats what i thought, but theres nothing in the bios, look at link i provided.. screenshots of the bios is on there!
bump
your pcie slot is inactive , thats why your card isnt being detected have you installed your mobo drivers?
yesyesyes. This is highly irritating.
you sure its all connected properly? perhaps its a defective card?
| Similar Threads | ||||
| GeForce 8800GT ? failure | jonmal123 | Graphic cards | 38 | 16 Nov 2009 |
| XFX 8800GT graphics card problem...??? | Looser007 | Graphic cards | 6 | 20 Mar 2009 |
| NVIDIA 8800GT for MAC on PC ??? | cqui3 | Vista hardware & devices | 1 | 10 Sep 2008 |
| Vista Ultimate 64 8800GT problem | ISDP | Graphic cards | 19 | 17 Feb 2008 |
| About the alpha blend and alpha test in 3D | Arthur_liu | Avalon | 1 | 10 Jan 2006 |
