Solved POWERCOLOR HD3650 1GB graphics problems
nostaw5
"POW" Ur dead
Power User
HI
me again
I have a new system. but heres the thing:
Games made about 10 years ago are laging. This includes Half Life and Colin McRae rally 2.0. I looked at the requirements for the games and here is what CMR 2.0 comes up with
MINIMUM
CPU: 233MHz
RAM: 32MB
Graphics card: 8MB
Directx: 7
MY SPECS ARE
CPU: 3.6GHz
RAM: 1.2 GB a 1gb stick and 256MB stick both running at 200MHz
GRAPHICS CARD: 1024GB dedicated at 700MHz
Directx: 9
OS: XP right now
ANYONE KNOW HOW TO STOP THE LAG. BOTH CPU AND GPU are overclocked. AGP apeture size is set to 32MB. The gpu settings are set for performance but all i get is lag
MY PC EVEN BEATS THE RECCOMENDED REQUIREMENTS FOR CMR 2..
PLZ PLZ PLZ HELP MEEEEE.
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Keyboard
    Logitech K120 Wired Mouse
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    Thomson A/B/G/N Router
    LiteON CD/DVD Player
    GAME PERFORMANCE:
    Battlefield 3: 41 FPS High 1x AA @ 1280x720
    Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080
    Counter Strike Source (and other Valve games):
    300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
HI
me again
MINIMUM
CPU: 233MHz
RAM: 32MB
Graphics card: 8MB
Directx: 7
MY SPECS ARE
CPU: 3.6GHz
Directx: 9
OS: XP right now
I think the settings are fine, there maybe a possibility that what you are seeing on screen isn't lag but something called vertical tearing (even though its often seen as diagonal) but it will be percieved on screen like the monitor cannot catch up to the graphics card, hence you will see the screen morphing every few milliseconds, to fix this, you will need to open up the catalyst control center and find the v-sync (vertical sync) options and set it to on, the games should be running fine once this is set!
Dave
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
No its definatly lag (lag-lagg who cares). I already knew about the v-sync but the games actually LAG, LAGG. Im guessing its either my awful 300w psu or my crap intel celeron 320 clocked at 3.6GHz. It cant even handle battlefield 2.
Anyway the games run smooth until 5mins in it lags like hell. EVEN DVD Movies DO THE SAME
Here is my pcs FULL specs
OS: Windows Vista Home Edition
CPU: Intel Celeron 320 Clocked at 3.6GHz
POWER SUPPLY: 300w ATI reccomends 350w
RAM: 1270MB 1GB + 256MB
GPU: PowerColor Radeon HD 3650 1GB agp
HDD: Seagate 80GB 7200RPM
As i said it could be the psu or the CPU. the ram is fine cuz i got the same on my laptop. Itplays games well with 64MB dedicated. And 1GB as my other 2GB broke.
WTF is wrong
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    GAME PERFORMANCE:
I can't see your CPU being the problem (although it is counted as an everyday budget processor), however if you were to get a new CPU (dual/quad core) you still have the issue of power, you could pick up a cheap power supply at your local computer store or market.
Dave
    16Mb Sky bb
Ditch the 256megs and see what happens.i DON'T THINK ITS RECOMMENDED TO, srry, run like that.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
hi thanks all. i will give u rep. i guess i will get a new psu but there r no 478 socket processors running dual apparently. Are psus for 2004 dated mobos still around. im using old school psu with no sata connectors and stuff.
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    GAME PERFORMANCE:
Oh yha, theyre all still good. They have both connectors. Theyre called 4-pin molex or peripherals.
Only thing "New" is the sata power connector, and most main power cables are 20+4 cables.... you detach the extra 4 if you have a 20pin power socket.
You know, I never even thought about the 478 sockets lol, there aren't any dual core 478's. however you could have Hyper Threaded P4? i'd recommend the 3GHz P4 anyday, it served me well when I had one.
Patonb is right, you can get a PSU that is backward compatible with older Motherboards, id recommend something like a 600W or a 650W, that will future proof your system for a while at least.
Dave
    16Mb Sky bb
Ha thanks guys. About the P4 hyper threaded p4. UMMM whats the difference between the 2 cores and hyperthreading?
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    GAME PERFORMANCE:
Hyperthreading is 1 real and 1 virtual core... What happens is the cpu works on 2 things at once. As 1 process takes a break, the second process gets crunched.
2 cores is just that... 2 cpus on 1 chip, with each chip doing its own prrocesses.
2 real cores beats 1 real and 1 virtual.
