Originally Posted by
puresaff
I was playing an old game on my computer with my little brother and the display totally mucked up and I've had to try and re-set the monitor display but none of them look right, can anyone help me? I've got a 16 inch laptop but can't figure out which one to use, can anyone help me??
Thank you!
Suggestions :
1. Re-set DPI :
Right click on an open space of the desktop > Personalize > left column, Adjust font size (DPI) > uac prompt > click Default scale (96 DPI ).
2. Resolution :
Right click on an open space of the desktop > Personalize > Display Settings > move the slider until you find a suitable resolution. Check your user manual, see if it tells you which resolution is for your computer.
Here is a table of guide line:
3. Do a system restore. Pick the date when your screen was in proper size as your restore point. Start button > search box, type system restore >press Enter key > uac prompt > click Choose a different restore point > Next > select the date as your restore point, click it > Next > Finish Sit back and wait. The machine will re-start when it is done.
