Hello, I recently installed win7 hoping that it will make mytrading software work better. Problem I’m having is that the area on the chartthat shows volume is blinking. The brightness is simple going from normal tomore bright (if that makes sense). I’ve pretty much tried everything. I have 2 GTX 285 GPUs I triedswapping them, I’ve tried using current, beta and even older drivers andnothing has helped. The one oddity is when this issue occurs and I go into the nvidiadrivers setting the mouse pointer seems to blink frequently when I go over theblue setting selections that are in their driver settings software. I have notnoticed other problems in any other software (COD works fine). I had their techguy on and he was of no help (what a shocker) they logged into my comp andbasically he said he saw it on his end as well. I was wondering if you guys mayhave any ideas.
Thanks,
Sebastian
P.S. it should show here as I put it in on reg, but mycpu is an i7 920 and I have corsair 1600 mhz mem and an asus P6T (the avg one)MOBO. I have tried update dating everything in site so all of my drivers are upto date and like I stated above the GPU drivers are beta.
