Go Back   Vista Forums > Vista Forums > Graphic cards
Vista Tutorial - SLI Problem
Old 09-29-2007   #1 (permalink)
I知 a PC
Windows 7 Ultimate x64
SLI Problem
I am trying to set up SLI on my system, but every time I enable SLI in the nvidia control panel my screen flashes a few times followed by a message to say that the display driver has crashed then a BSOD
Drivers I have tried so far
162.22
163.67
163.69
Ideas anybody?
Old 10-04-2007   #2 (permalink)
Vista x64 Ultimate
Re: SLI Problem
I dont know if its a problem isolated to the geforce 7950gx2 but i had the same issue and it was due to my card not liking 4gb of ram. I took 1 out and tried and it worked flawlessly. You might want to give that a try and see if it helps before troubleshooting forever
The issue only came about when trying to switch to multi-gpu from multi-display. it worked fine on multi-display.
EDIT:
Damn nice specs BTW
Old 10-05-2007   #3 (permalink)
I知 a PC
Re: SLI Problem
I dont play games so i'm realy not that bothered about SLI enough to lose 1gig of ram
Old 10-05-2007   #4 (permalink)
Vista x64
Re: SLI Problem
Tried getting the newest drivers? I don't think that it should matter that much if your not into games. Sell one on ebay or something. My friend has a 8600GT and runs all settings on high for his games (this is overclocked). You should be fine with one. Maybe try calling them up though.
Old 10-05-2007   #5 (permalink)
I知 a PC
Re: SLI Problem
I have got to have two cards due to running 3 tft's on it, I just wanted to try the SLI thing, its not like it was going to get and use other than running a few benchmarks lol
Old 04-06-2008   #6 (permalink)
Newbie
Windows Vista Ultimate x64 SP1
Re: SLI Problem
Try download new driver from Nvidia site that may fix the problems - I used 2xXFX Nvidia Geforce 9600GT XXX and enabled SLI (used 174.74 driver that latest one) plus used Thermaltake Toughpower 1000w PSU - that worked prefect that keep cooler and very fast run - no problems at all -- I also plugged 4-pins Molex into PCIE_12v to give more power that what it said on motherboard manual (used GA-M59SLI-S5 + Athlon 64 X2 6400+ 3.2Ghz + 4Gb RAM DDR2-800)
Old 04-06-2008   #7 (permalink)
SteveM
Guest
Re: SLI Problem
Quote  Quote: Originally Posted by z3r010 View Post
162.22
163.67
163.69
Ideas anybody?
Hi.
I have 2 x XFX geforce 8800 GT and 169.32 driver I think you need to update.
Old 04-06-2008   #8 (permalink)
I知 a PC
Re: SLI Problem
If your not having any problems, then leave well alone.
Old 04-06-2008   #9 (permalink)
I知 a PC
Re: SLI Problem
Quote  Quote: Originally Posted by Lucky0967 View Post
And today's Vista Forums "Frankenstein" award, for raising dead threads, goes to Lucky0967
Lucky0967 - please take a bow
Old 04-28-2008   #10 (permalink)
Newbie
linux
Re: SLI Problem
it's very very easy if you have a gigabyte ga-x38-ds5. this motherboard only supports ati crossfire......x38 only works with ati not nvidia....if you want performance have to go to ati hd 3XXX or the coming 4XXX
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
ゥ Designer Media Ltd
