| home premium 64 | vista 64 home premium no sound I have no sound in media center, dvd and music play fine in windows media player but nothing in the media center. It will play prerecorded movies from a network connection on another machine but no sound from speaker test or beebs at page changes tv tuner is silent too. |
| Vista Home Premium | Re: vista 64 home premium no sound I have no sound in media center, dvd and music play fine in windows media player but nothing in the media center. It will play prerecorded movies from a network connection on another machine but no sound from speaker test or beebs at page changes tv tuner is silent too. |
| home premium 64 | Re: vista 64 home premium no sound I believe it was a codec pak that I installed trying to play mp4. I made such a mess that I ended up reinstalling the os and have converted all my media files to mpg. |
| Vista Home Premium 64 bit | Re: vista 64 home premium no sound I have fixed an issue with DVD sound on Windows Media Center that I was having and thought I would pass this on so that it may be of help to others with the same issue. The issue is that when I played a DVD on Media Center, I would get video but no audio. Many suggestions were made that it was due to missing codecs, but efforts to supply codecs did not remedy the situation. Here is what did fix this issue: This fix only applies to systems where you have an HDMI connection directly from your computer to your TV. I happen to be running Vista Home Premium 64 bit, but I think this would apply to 32 bit as well. 1. Open Control Panel. 2. Click on Hardware and sound. 3. Click on Sound. 4. Click to highlight Digital Output Device (SPDIF). 5. Click on Properties. 6. Select the "Supported Formats" tab. 7. Under "Encoded Formats" you will see three items with tick boxes. These items are DTS Audio, Dolby Digital, and Microsoft WMA Pro Audio. All three of these boxes must be NOT TICKED. That is the key. Make sure all of these boxes are not ticked. I believe one or more of these tick boxes are used when your SPDIF signal goes from your computer to an audio amplifier, but if you are set up like I am where your SPDIF signal is incorporated into the HDMI cable and the HDMI cable runs directly from your computer to your TV, then these tick boxes must be not ticked. |
| DTS sound in Vista Home Premium 32bit | Vista hardware & devices | |||
| Poor Sound under Vista Home Premium | Vista General | |||
| Sound problem acer vista home premium | Vista music pictures video | |||
| sound recorder-Vista Home Premium | Vista General | |||
| Sound problem with Vista Home Premium | Vista General | |||
