Vista Forums Home Join Vista Forums Webcasts Windows 7 Forum Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > Network & Internet
Connection and DNS problems
Update your Vista Drivers Update Your Drivers Now!!
Thread Tools Display Modes
Old 05-19-2008   #1 (permalink)
Newbie
Vista
Clare is on a distinguished road
  Clare is offline
Hey
Firstly please bear with me as I am clueless and some what a computer noob. :P
I have three computers, two with XP and the other which is new with Vista. My new computer with Vista on it is causing me no end of problems. :/ Basically it wont connect to the internet .. it does briefly then won't. Ive tried to repair and fix it but to no avail. It says that I have a DNS problem, have tried the ipconfig/flushdns, but that doesn't work. I have read lots of forums regarding this but seriously I am a noob and dont understand half the stuff it says for me to do.. I know its sad but true!
I am thinking there could be a conflict between my xp and vista through my router, but once again havent got a clue how to check it .. or if I need to buy a new one, which is the one I should get.
Any help would be appreciated, I am sorry for being so clueless, just well bleh I am. :P
Thanks in advance.
Old 05-19-2008   #2 (permalink)
Guru
Vista x64 Ultimate
SCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud ofSCSIraidGURU has much to be proud of
  SCSIraidGURU is offline
Re: Connection and DNS problems
Go into the network controller properties. Click on the the NIC properties and find link speed and duplex. Might be speed and duplex. Depending on controller. Set it to 100 Mbps / full duplex instead of auto / auto. See if that helps. You might also need to add that computer into the MAC filter list on your router to get it through your router.
Old 05-20-2008   #3 (permalink)
soldatz's Avatar
Junior Member
Vista Ultimate x64 SP1
soldatz is on a distinguished road
  soldatz is offline
Clare, try to make sure that your network adapter is set to automatically get an IP settings from the router (this is called DHCP). I believe this setting is under your TCP/IP properties.
Doing this will allow Vista to grab an IP address and DNS settings from the router.
I don't see how XP and Vista could conflict through the router. I have 3 XP, 1 Vista and 1 Linux PC at home, and there are no connectivity conflicts at least as far as connecting to the Internet.
Old 05-20-2008   #4 (permalink)
Engineer
windows vista ultimate
Colombo, Sri Lanka
john_cena is just really nicejohn_cena is just really nicejohn_cena is just really nicejohn_cena is just really nicejohn_cena is just really nice
  john_cena is offline
hi Clare,
You could also try the follwoing.
Go to network & sharing center
click manage network connections.
open your local area connection
double click tcp/ip
click advance
In defults gateways say add
put your routers ip address over there
Note := make sure your getting a DHCP Ip address from your router. the means on your network settings it should be stated as obtain ip address automaticaly
if this doenst work go to commad prompt and type ipconfig /all. and paste the results over here
Hope this helps
Cheers !!
Display Modes
Connection Problems Sargeant Rutter Vista networking & sharing 1 04-26-2008 12:26 AM
Connection problems...PLEASE HELP!!! hfbs1234 Network & Internet 3 12-11-2007 10:39 AM
VPN Connection Problems Tim S. Raisbeck Vista General 0 04-11-2007 08:39 PM
IE 7 Connection problems & Windows Mail Connection PB90 Vista General 1 03-09-2007 10:19 AM
Problems with connection Matt Vista General 9 10-16-2006 07:19 PM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
