Vista - Belkin usb wireless adapter problems
Old 02-05-2008   #1 (permalink)
Vista Home Premium 64bit
Hi. I recently installed Windows Vista home premium x64 on my Athlon 64 system and
plugged in my Belkin F5D7050 wireless G usb adapter, only to find out that,
of course the drivers didn't work. Went online, using my laptop, downloaded the latest and greatest drivers and I installed the driver and the device still doesn't work.
For instance, when I set it to search for wireless networks nearby (which it
should find mine), the activity light on it doesn't even flash once. It
hasn't flashed ever since I plugged it in after installing Vista. So my
question is, is there a driver that would work with my adapter, and if there
isn't could you recommend a low cost wireless usb adapter that would work
with Vista home premium x64? Thank you for your help, sword182.
Belkin N1 Wireless USB Adapter Version 3 Network & Sharing
Solved Belkin 54g USB Wireless Adapter - Driver? Drivers
Belkin G+ Wireless USB Adapter Vista hardware & devices
Belkin Wireless Adapter Drivers
Belkin Pre-N Wireless Desktop Adapter Vista hardware & devices
