Vista - how to auto connect to wireless networks which requires identification?
Old 05-10-2008   #1 (permalink)
Vista Business 32bit
i've set my laptop to auto-connect to a wireless network, but it'll ask for identification because it's a secure network. is it possible to automate the filling process too, so that i don't have to type everytime? i have to enter my username, password and another field which i can't rem. >.< there is a check box on the prompt pop up screen which says that the above information can be saved when checked, but it's greyed out, so i couldn't check it.
sorry if there's another thread of the same kind elsewhere, but i don't know where to find help of this type.
Old 05-10-2008   #2 (permalink)
Vista Home Premium 64bit
Re: how to auto connect to wireless networks which requires identification?
Down in the right corner of your monitor near your time in your system tray should be a network icon for wireless connection. Right click on it, select connect to, or view available wireless networks, select your network and enter the WEP or security key you got with your router, if you are unsure of your key consult your routers documentation or the router manufacturers website on how to obtain that info. Once you connect and input the key you should be on the network and receive a valid IP and be able to browse.
Try this out!
Old 05-10-2008   #3 (permalink)
er, i can auto-connect. but i want to make my username and password for secured networks automatically filled in for me, so i don't have to keep typing it everytime i want to connect. it's esp bad when the laptop just doesn't seem to accept my correctly type username and password, causing me to enter multiple times before finally connecting.
Old 05-10-2008   #4 (permalink)
Unless there is a remember password box and you have set windows or IE to autofill I don't think what you are asking is going to be possible. I could be wrong though. :P
Old 05-10-2008   #5 (permalink)
there is a remember password thingy box. but it is greyed out, as mentioned in my first post. is there a way to make it checkable?
Old 05-10-2008   #6 (permalink)
Ultimate SP1 x64 & x86
How does it look like in the properties/security tab of your network?
Old 05-11-2008   #7 (permalink)
er.. here goes..
security type: 802.1X
encryption type: WEP
choose a network authentication method:
Protected EAP (PEAP)
[checked] cache user information for subsequent connections to this network
when my laptop automatically finds the network, it will show a notification at the bottom right corner that says something like "additional information is required to connect to this network". i'll have to click that and fill in my username etc.
Old 05-11-2008   #8 (permalink)
I guess you use a special identification which has nothing to see with your Windows login/password. The greyed out box is (i think) related only with your Windows login.
If is is a professional or university network, maybe you have to enter your login/password each time you connect to the network.
Old 05-11-2008   #9 (permalink)
aww. that stinks. my fren's mac could do that. rawr. thanks anyway. =.=
my HP laptop wont connect to any wireless networks Vista networking & sharing
Automatically connect to unsecured wireless networks in Vista Network & Sharing
Cannot connect to any wireless networks in Vista Network & Sharing
Vista sp 1 (64bit ultimate) - cannot connect to wireless networks Vista networking & sharing
multiple copies of networks and no auto connect Vista networking & sharing
