Vista - IP Address help! Home Premium
Old 05-17-2008   #1 (permalink)
32bit
Ok i need some help, with changing my IP Address.
Details; i'm with Virgin media broadband i'm using a cable modem..
and i've read how to change it; Via the
Network > Manage network connections > Porperties...
Doesnt work it tells you...
"Obatain and IP address automatically."
But mine is already set to that...
and with the
"Use this IP address." option i don't know what to put in,
for the simple fact i wouldnt want to put in an invalid IP...
Please somebody help!
Old 05-17-2008   #2 (permalink)
Ultimate SP1 x64 & x86
Re: IP Address help! Home Premium
Hi Whiteley,
Did you already have a connection or are you setting it up?
Can you give us some more information.
Run the command prompt console and type in: ipconfig /all
Copy/past the result.
Old 05-17-2008   #3 (permalink)
Vista Home Premium
set the IP Version to 4 vista might end up using the IPV6 follow the steps below :
1. Open Network Connections by clicking the Start button , clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, and then clicking Manage network connections.
2. Right-click the connection that you want to change, and then click Properties. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3. Click the Networking tab. Under This connection uses the following items, click Internet Protocol Version 4
Old 05-18-2008   #4 (permalink)
32bit
Quote  Quote: Originally Posted by sidney1st View Post
Hi Whiteley,
Hi yep here it is!
C:\Users\Dan>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Dan-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : USB Cable Modem 351000
Physical Address. . . . . . . . . : 00-0E-9B-E5-C9-11
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::2056:8878:6186:577c%10(Preferred)
IPv4 Address. . . . . . . . . . . : 81.105.104.19(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.252.0
Lease Obtained. . . . . . . . . . : 18 May 2008 11:17:48
Lease Expires . . . . . . . . . . : 23 May 2008 15:31:13
Default Gateway . . . . . . . . . : 81.105.104.1
DHCP Server . . . . . . . . . . . : 62.252.224.28
DHCPv6 IAID . . . . . . . . . . . : 218107547
DNS Servers . . . . . . . . . . . : 194.168.4.100
194.168.8.100
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Intel(R) PRO/1000 PL Network Connection
Physical Address. . . . . . . . . : 00-1C-25-3D-5E-2B
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : isatap.{FC799986-BA3F-4FF4-9211-96BDBD7A5
E3E}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : isatap.{54C03730-27C2-48CE-966C-B0874D7D3
780}
Link-local IPv6 Address . . . . . : fe80::200:5efe:81.105.104.19%12(Preferred
194.168.8.100
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : 6TO4 Adapter
Temporary IPv6 Address. . . . . . : 2002:5169:6813::5169:6813(Preferred)
Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
194.168.8.100
Tunnel adapter Local Area Connection* 10:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Link-local IPv6 Address . . . . . : fe80::30c3:ba:ae96:97ec%11(Preferred)
C:\Users\Dan>
Don't know if that helped buddy but you wanted it
Old 05-18-2008   #5 (permalink)
windows vista ultimate
hi Whiteley,
If your setting up a new Connection to the internet the configuration shown in your Ip config is the ISPs IP address whihch is correct. Are you able to connect the internet. If your want to have a small home network or such then you need to configure a manual ip.
you could use ferrisits post or. you can go to command propmt and type in the following
netsh interface ip set address name="Local Area Connection" static 192.168.0.100 255.255.255.0 192.168.0.1 1
where 192.168.0.100 is the ip address
255.255.255.0 is the subnetmask
192.168.0.1 is the defult gateway.
You need to put the Ip address according to your network i have given only a example
Hope this Helps .
Cheers
Old 05-18-2008   #6 (permalink)
32bit
Quote  Quote: Originally Posted by john_cena View Post
hi Whiteley,
Hope this Helps .
Cheers
Thanks, could you break it down a bit for me?
Like what ferrists said i don't get it..
He wants me to input my own IP...
But will any IP Work?
Old 05-18-2008   #7 (permalink)
Well, try with 194.168.4.210 as your ip address
255.255.255.0 as mask
194.168.4.100 as gateway
And dns 1: 194.168.4.100
dns 2: 194.168.8.100
Old 05-18-2008   #8 (permalink)
Hi Whiteley,
No you cant use anyip if your connecting to a router your router would have a Ip series it uses you could use a ip from that. If your using a modem that uses a direct link from your ISP then u need to obtain it automaticaly. to get a Ip automaticaly from your ISP do the follwoing in Command Propmpt.
open command propmpt.
copy paste the following Provided that your connection name is Local area connection
netsh interface ip set dns "Local Area Connection" dhcp
Hope this helps
Cheers !!!
Old 05-18-2008   #9 (permalink)
32bit
Sorry mate but the automatic is what it's already set to
I just need to know how to change it
Hi Whiteley,
Hope this helps
Cheers !!!
Old 05-18-2008   #10 (permalink)
Hi Whiteley,
You can change your IP by looking at my previous post. But if you do so like i said you need to know the IP address from your ISP. Normaly ISP s dont give static Ips to users. They used to give it long time back when there were dialup connections. You cant use any ip address beacuse Thoese Ip address wont be valid with your ISP.
Hope this helps..
Cheers
Importing Address book from Windows Mail (Vista Home Premium) to Outlook Express v6 (XP machine) Vista mail
Home Premium -> Ultimate; Can I use the old Home Premium license? Vista installation & setup
Remote Access from Vista Home Premium to Vista Home Premium and XP Home Edition Network & Sharing
Updating from Home Premium to Ultimate and moving Home Premium Vista installation & setup
Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H Vista General
