Vista - wireless connectivity issues
Closed Thread
Old 05-30-2008   #1 (permalink)
Vista Home Premium 32bit
I am running Vista Home 32bit and my computer (laptop) will not recognize my wireless router. It tells me that I have limited connectivity and no internet connection. My wifes laptop picks up the signal fine and has no issues. Service provider can't help, manufacturer can't help. The really weird part is that I check to see if I can pick up unsecured signals and it works every time! What do I do?
Old 05-31-2008   #2 (permalink)
Ultimate SP1 x64 & x86
Re: wireless connectivity issues
Try first to reset your tcp/ip:
Run CMD as administrator
Type in: netsh int ip reset
Press Enter
Reboot.
Old 06-01-2008   #3 (permalink)
Thank you for the help. I figured out the problem. It was as simple as downloading service pack 1. I thought my computer was already downloading updates automatically but that's what I did and no problems since. Thanks again for the advice!
Closed Thread
Wi-Fi Connectivity issues Vista General
New Intel Wireless Drivers for Vista Available, may solve some of the Wireless Connectivity Issues Vista networking & sharing
US Robotics 805422 Wireless USB Adaptor Connectivity Issues Vista networking & sharing
Connectivity issues Vista networking & sharing
