| Junior Member | Remote Desktop Help Okay you networking gurus I need some help. I have a machine at home running Vista and one at work running Vista and would like to use remote desktop to my work machine so I can work from home when I need to. I am hoping I can use the setup in Vista without having to buy Gotomypc. I can make the remote desktop work flawlessly in the office between two machines but I cannot access my office from home for some reason. Anyone with experience at this HELP! |
| Antidisestablishmentarian | Re: Remote Desktop Help RD will require various special ports forwarded on your router (if you have one) and ports allowed in your firewall (Vista by default has a firewall, so even if you haven't installed one it is there) before you can do it. Another solution would be to use VPN, see the VPN thread in this forum as well. |
| Junior Member | Re: Remote Desktop Help Can you giveme the port info to setup the roputer or point me to the location of the information? |
| Vista Vet | Re: Remote Desktop Help Computer-Ed, try looking here: PortForward.com - Free Help Setting up Your Router or Firewall I find that they have almost EVERYTHING you need when it comes to router/firewall issues. |
| Remote desktop can not find remote computer | Network & Sharing | |||
| Can't login to remote comp. using Remote Desktop Connection on Vis | Vista account administration | |||
| Remote Desktop problem with remote printers | Vista networking & sharing | |||
| remote desktop connection? AKA remote access? | Vista General | |||
| Remote Desktop - Able to have one user logged in locally and one user via remote desktop? | Vista networking & sharing | |||
