Vista - Wireless Network Connection
Old 08-04-2008   #1 (permalink)
Premium32 Ultimate32 Pro
Ultimate, Premium, Pro & Home
Installed new router and changed network name from mynet to MyNet. After signing on with new key I now have Mynet 2 under wireless network connection and in the system tray. Not causing any problems but this isn't what I wanted.
On the other OSs how can I sign on with the new key and not get a second wireless network connection of MyNet 2 ?
On Premium how can I get this back to mynet or MyNet (without the 2) ?
Thanks for the help.
Old 08-05-2008   #2 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Re: Wireless Network Connection
You'll have to delete both mynet and MyNet - then re-connect to MyNet.
Same on the others - delete the old ones first.
Old 08-05-2008   #3 (permalink)
Quote  Quote: Originally Posted by johngalt View Post
Delete from where ?
Old 08-05-2008   #4 (permalink)
from your list of connections using the Vista Wireless Connection manager....
Old 08-06-2008   #5 (permalink)
No joy here for repairing one already labeled MyNet 2, also tried with reboot. Reconnects as MyNet 2. Also MyNet 2 & mynet remain in the registry.
I was able to make the necessary changes in the registry by deleting mynet entries and then changing MyNet 2 to MyNet.
Maybe the correct method would be to delete the active "mynet" entry before disconnecting the original router???????????
Old 08-06-2008   #6 (permalink)
I don't personally use wireless, but I thought that you are able to remove connections from the list even if you are not connected to them.
Yup - see Vista Hands On #10: Manage wireless networks | Ed Bott’s Microsoft Report | ZDNet.com
Old 08-06-2008   #7 (permalink)
Quote  Quote: Originally Posted by glatzfront View Post
Sorry, guess I wasn't clear, I was able to delete them but this didn't help. When I signed back on, MyNet 2 was still there.
Old 08-06-2008   #8 (permalink)
Then follow the delete process, then remove all instances of mynet from the registry and mynet 2 from the registry, reboot and try connecting - it should ask to create a brand new connection, and hopefully name it Mynet.
Old 08-06-2008   #9 (permalink)
Thanks
Wireless Network Connection Problems Vista networking & sharing
Losing wireless connection to specific wireless network Vista networking & sharing
Wireless network establishs a public network connection Vista networking & sharing
Limited connection with wireless network Vista hardware & devices
wireless network connection Vista performance & maintenance
