| x64 | Network Problem Well here goes, couldn't find my answer searching: I'm running Vista Home basic 64bit sp1. My Network icon displays a red-x, and when I mouseover it I get "Connection Status: unknown Server execution failed". If I try to enable Network Discovery I get this error message: "No such interface supported" and then a system message "Network Store Interface Service has stopped working". So I can't see anything or anyone on our network(three other computers connected all running XP) however I have no problem connecting to the internet. Need more info let me know Thanks in advance for any help |
| vista home premium 64 oem | Re: Network Problem Are we talking about the computer that is connected to your router or one that is wireless. You may not have your security set for discovery and file shareing. Is your firewall on. If so temporarly turn it of and see if you still have the problem. |
| x64 | Re: Network Problem The computer is wired directly to the router. When I disable the firewall it changes to message in the Network and Sharing center to "Unknown The service to detect this status is disabled" if I click the more info link I get a prompt to start the Network List Service. If I click turn this on I get an error message "Windows Connect Now - Config Registrar has stopped working. Also, if I try to enable Network Discovery nothing happens. |
| Vista Network Problem / Sharing / Computers not Showing on Network | Vista networking & sharing | |||
| Problem with Network printer over wireless network. | Vista print fax & scan | |||
| Strange network problem - Can't save in Office2007 on network driv | Vista networking & sharing | |||
| Vista Network Problem - lose network | Vista networking & sharing | |||
| Network Printer and Wireless Network problem | Vista installation & setup | |||
