Vista - 2nd time connection problems
Old 10-23-2008   #1 (permalink)
32bit
Hi
I may well be being an idiot(!) but regardless I was hoping someone may be able to guide me in the right direction..........
I have just bought a Dell XPS 1530 which runs on Vista Home
I am having a problem getting online.
This is exactly what's happening..............
I have a desktop which connects to a broadband connection via a network cable - this works perfectly everytime
When I first plugged this cable into my new laptop I successfully got online and installed a few drivers etc and all seemed well
I then tried out the built in wireless connection in my local coffee shop - I got the password from the waitress and again successfully got online
The problem is that I can't seem to connect to the internet through the same cable / wireless more than once !!
My laptop simply will not connect again at home and I've also found this to be true at the coffee shop - I've also been round a friends used their cable plugged it in - fine. Tried to use it again the next day and it wouldn't connect no matter what I tried
This is driving me nuts can anyone suggest what the problem is
I have installed AVG (free version) and also Zone Alarm - I did think maybe Zone Alarm if affecting my second time connection ? I have however run it for several years on XP with absolutely no probs
PLEASE HELP
thanks
Sid
possible internet connection time out Network & Sharing
Wireless PCI connection time Network & Sharing
Time out of internet connection Vista General
connection breaks every time Live Messenger
IE 7 Connection problems & Windows Mail Connection Vista General
