Vista Tutorial - Network Cable Unplugged Issue
Old 11-09-2008   #1 (permalink)
Newbie
Vista Home Premium 32bit
Click the image to open in full size. November 10th, 2008, 12:55 AM Click the image to open in full size. #1 (permalink) phufool
Junior Member
I live in a college dorm and my internet used to work fine until I used my friend's ethernet jack in his dorm. He uses a "switch" that allows more ethernet jacks to be plugged in and I think this messed up my Local Area Connection somehow. Now when I try using the ethernet jack in my room it says "Network cable unplugged" even though I know it is plugged in and is working. The internet works fine if I plug it in my friend's jack though. Anyone know what I can do to fix this? This happened before and I messed around with the Speed & Duplex Settings and it worked... but now when I try that it doesn't work anymore!
If I change the Duplex Setting to 100mbs full, it detects an unidentified network with limited connectivity, but the internet still doesn't work
network cable unplugged error Network & Sharing
Network cable is NOT unplugged...hello windows! Network & Sharing
Network cable unplugged Message Vista networking & sharing
Can use Internet - not network. says cable is unplugged - it's not Vista networking & sharing
Vista - Network Cable Unplugged Vista networking & sharing
