| Vista Home Premium | Printer connection problems I am trying to connect a printer (Dell 968 AIO) using bonjour on airport express, I am running windows vista home premium, I have connected the printer directly to laptop and this has worked on the system, but on occasions does have an error of 'unable to communicate' when I do plug the USB in to the airport and run bonjour it states that there is no bonjour printer available, I've turned off windows firewall, but still no joy, I do have Norton protection running, can anyone help????? PLEASE. |
| Vista Home Premium x86 (32bit) | Re: Printer connection problems I'm not quite sure what it is that you're using, as I've never used it myself. But check the following. Start> Right Click Computer> Manage> Services and Applications>Services Make the following set to Automatic Start Up Type (Double click or right-click then properties) Printer Spooler Plug and Play Good Luck ![]() ~Akitakara |
| Refreshing connection to WHS printer | Vista print fax & scan | |||
| Connection problems for shared printer | Vista networking & sharing | |||
| Printer not establishing connection | Vista General | |||
| IE 7 Connection problems & Windows Mail Connection | Vista General | |||
| home network and printer connection problems with XP and Vista | Vista General | |||
