Vista - wire less connection having problem
Old 12-01-2008   #1 (permalink)
Vista Home premium 32 bit
Dear Friends,
In my laptop I have configured my wireless network ip as obtain automatically, but the connection is not established through wireless, but the connection is established, while connecting the wire. Can you give me a solution for this. Some time the connection establish through wireless.
thanks & regards
vinayan
Old 12-01-2008   #2 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Re: wire less connection having problem
How is your signal strength on the connection you're attempting to connect to?
Virtual Server 2005 & Internet Connection Sharing (ICS) using Wire .NET General
Re: WLM On-the-wire security Live Messenger
2 Wire with Vista connection problems Vista networking & sharing
