| | Vista - NB HP and VISTA - does not work LAN |
| 12-25-2008 | #1 |
| Vista Ultimate 32bit | NB HP and VISTA - does not work LAN Hallo, I have NB HP 6730s with vista ultimate, but the LAN doesn´t function. I have installed original driver which I downloaded from hp.com, but it doesn´t function. It reports an error: "This device cannot start. (Code 10)". Could you please help me? Although I reinstall Windows, there was the same problem. In bios it´s enable. Thank you for your advise, luke |
| 12-28-2008 | #2 |
| Vista Enterprise | Re: NB HP and VISTA - does not work LAN If you're using the correct drivers and still have issues i sugest a hardware problem. |
Similar Threads for: NB HP and VISTA - does not work LAN
| speakers randomly wont work sometimes on laptop but external will sometime work | Sound & Audio | |||
| Still searching for way to get Vista search to work: Why doesn't FilterFilesWithUnknownExtensions registry key work in Vista? | Vista General | |||
| all cd's don't work, but dvd's still work | Vista hardware & devices | |||
| HP LaserJet 1010 don't work in Vista since Beta2 - Advanced 1384 Printing Support drivers for XP don't work | Vista print fax & scan | |||
| Will all the programs that work on xp work on vista? | Vista General | |||
