| vista | wireless worked on xp not on vista - HELP! my wireless connection worked on my xp laptop, but i cannot get it to work on both of my vista laptops. it shows the network but won't connect to it. i tried disabling the ipv6 but that didn't work. i'm trying not to spend the money to have geeksquad do it for us - any ideas on how to get it to work? |
| Vista Ultimate X64 SP2 | Re: wireless worked on xp not on vista - HELP! I need to know your config, and then i will help you set it up. |
| Vista Ultimate X64 SP2 | Re: wireless worked on xp not on vista - HELP! First, what are you using? wireless router...with wpa/wep/MAC filtering? If your network shows as "secured" you will need to enter your key after you click "connect to network" You can recover this key from your xp machine (see attached) Here is an easy fix if the above info/key is unknown: step 1 there should be a little reset "hole" on router- usually in the back. Push it in with paperclip, or push pin and hold it there for 30 seconds. step 2 Unplug power from modem and router step 3 restart notebook/power up modem and router step 4 You should now see your unsecured network (linksys/netgear/Belkin/D-Link) click connect to your network (name of router) note- In the event your internet is down you will still see the network, but you will not be able to connect. if you are set up for WEP/WPA secured network, you can "reset" the connection by powering down the router/modem and powering them back up. DO NOT RESET THE ROUTER as this will restore the factory default settings and wipe out configured settings such as encryption and filtering. Last edited by rive0108; 12-26-2008 at 12:47 PM.. |
| vista | Re: wireless worked on xp not on vista - HELP! it was a secured network when i used it on the xp. i forgot the login info, but on both of the vistas it comes up as unsecured (but when i try to install the disc for the router i need that info) the xp broke so i cann't get the info from that. would it still work to reset the router and try it all over again? |
| vista | Re: wireless worked on xp not on vista - HELP! i'm using a netgear router if that makes a difference. i know there are a few updates for it, but i cannot download them since i can't install it. |
| | #6 (permalink) |
| Vista Ultimate X64 SP2 | Re: wireless worked on xp not on vista - HELP! just reset the router it will reset it to default without the passphrase/key |
| my games worked on xp but not vista | Vista Games | |||
| Wireless connection from ACER Travelmate 2700 worked ok on xp home | Vista networking & sharing | |||
| RE: Hey can I run games that worked on XP in In Vista ? | Vista Games | |||
| What wireless network PCI cards have so far worked straight away? | Vista networking & sharing | |||
| VPN connection worked in XP, does not in Vista | Vista networking & sharing | |||
