Vista - wlan problem
Old 01-03-2009   #1 (permalink)
Vista Home Premium 32bit
wlan problem
hey there,
i've got some problems with wlan, which i believe are resulting from those vista background scans.
to solve this i'd like to try out the wlan optimizer, which i've downloaded..but i can't figure out how to turn the optimizer on, it says disabled when i launch it and i have no idea how to change this..
would be happy if someone could help me !
Old 01-03-2009   #2 (permalink)
Vista Ultimatex64 Windows 7 build 7100
Re: wlan problem
Quote  Quote: Originally Posted by Chiba View Post
hey there,
Hi Chiba,
Welcome to the forum.
Do you need to right click the .exe and select run as Administrator perhaps??
I hope this helps
Pooch
Old 01-03-2009   #3 (permalink)
Re: wlan problem
thanks
if i run the .exe as administrator the outcome is the same.. the program itself starts, but stays at disabled..
Old 01-03-2009   #4 (permalink)
Re: wlan problem
thanks
It was worth a try I don't know this program myself so I wont be much help
Maybe you could do a google, see what you can find
Pooch
Old 01-03-2009   #5 (permalink)
Re: wlan problem
like here for instance;
WLAN Optimizer .NET
WLAN problem Network & Sharing
Fix WLAN Autoconfig problem! Vista Games
Strange WLAN problem HP dv9500t Network & Sharing
Nokia E65 problem with connection through WLAN Network & Sharing
broadcom wlan problem Vista networking & sharing
