| 32bit | serious problem, limited connection I'll try to explain the problem The computer which I'm having problems with is having limited connection (this computer works on vista) with the cable and wireless now I have another laptop (which has XP on it) and this one works perfectly on the internet, wireless internet and cable... Facts: -the computer(vista) has had an internet connection for about a month, and stopped working last week -the WEP-key I used is correct and the same on both computers, I checked + double checked + triple checked -the computer (vista) gives limited access, local netwerk -when typing ifconfig /renew he says that I can't connect cause of the DHCP-server -I tried the KB928233 solution. (the thing with the flag, adding a DWORD32bit or sth,in your system32) -I unplugged the modem+router 15 times (waiting 30 seconds every time) -I have reinstalled the previous version of the wireless card and the cablecard with the same result (limted connection) -I have googled for solution and found some people that had a similar problem and I tried using their methods but these never worked -I have vista 32bit in the CMD I have already tried uitvoeren -> CMD code: netsh winsock reset netsh int ip reset reset.txt netsh firewall reset + rebooting (they were all succesful same result -when I type "IpConfig /release" in the black screen (opdrachtprompt) it says -when I type "ipconfig /renew" in the black screen it says that it can't connect with DHCP-server Microsoft Windows [versie 6.0.6001] Copyright (c) 2006 Microsoft Corporation. Alle rechten voorbehouden. C:\Users\Mauwrijn\Desktop>ipconfig /all Windows IP-configuratie Hostnaam . . . . . . . . . . . . : PC_op_attelier Primair DNS-achtervoegsel . . . . : Knooppunttype . . . . . . . . . . : hybride IP-routering ingeschakeld . . . . : nee WINS-proxy ingeschakeld . . . . . : nee Adapter voor draadloos LAN Draadloze netwerkverbinding: Verbindingsspec. DNS-achtervoegsel: Beschrijving. . . . . . . . . . . : 802.11 n/g/b Wireless LAN USB Adapter Fysiek adres. . . . . . . . . . . : 00-22-43-11-A2-23 DHCP ingeschakeld . . . . . . . . : ja Autom. configuratie ingeschakeld : ja Link-local IPv6-adres . . . . . . : fe80::9002:88a4:ac12:a134%13(voorkeur) Automatisch geconf.IPv4-adres . . : 169.254.161.52(voorkeur) Subnetmasker. . . . . . . . . . . : 255.255.0.0 Standaardgateway. . . . . . . . . : DNS-servers . . . . . . . . . . . : fec0:0:0:ffff::1%1 fec0:0:0:ffff::2%1 fec0:0:0:ffff::3%1 NetBIOS via TCPIP . . . . . . . . : ingeschakeld Tunnel-adapter LAN-verbinding*: Mediumstatus. . . . . . . . . . . : medium ontkoppeld Verbindingsspec. DNS-achtervoegsel: Beschrijving. . . . . . . . . . . : Microsoft ISATAP Adapter Fysiek adres. . . . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP ingeschakeld . . . . . . . . : nee Autom. configuratie ingeschakeld : ja Tunnel-adapter LAN-verbinding* 6: Mediumstatus. . . . . . . . . . . : medium ontkoppeld Verbindingsspec. DNS-achtervoegsel: Beschrijving. . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Fysiek adres. . . . . . . . . . . : 02-00-54-55-4E-01 DHCP ingeschakeld . . . . . . . . : nee Autom. configuratie ingeschakeld : ja C:\Users\Mauwrijn\Desktop>ipconfig /release Windows IP-configuratie Adapter voor draadloos LAN Draadloze netwerkverbinding: Verbindingsspec. DNS-achtervoegsel: Link-local IPv6-adres . . . . . . : fe80::9002:88a4:ac12:a134%13 Automatisch geconf.IPv4-adres . . : 169.254.161.52 Subnetmasker. . . . . . . . . . . : 255.255.0.0 Standaardgateway. . . . . . . . . : Tunnel-adapter LAN-verbinding*: Mediumstatus. . . . . . . . . . . : medium ontkoppeld Verbindingsspec. DNS-achtervoegsel: Tunnel-adapter LAN-verbinding* 6: Mediumstatus. . . . . . . . . . . : medium ontkoppeld Verbindingsspec. DNS-achtervoegsel: C:\Users\Mauwrijn\Desktop>ipconfig /renew Windows IP-configuratie Er is een fout opgetreden bij het vernieuwen van deze interface: Draadloze netwe rkverbinding. Kan geen contact met de DHCP-server maken. Aanvraag is verlopen. I assume the problem is somewhere in vista, and it probably has to do with the DHCP-server I hope someone is willingly to help me |
| Limited or No Connection | Network & Sharing | |||
| Connected but with LIMITED connection..?? | Network & Sharing | |||
| Limited Access - Wireless connection | Vista networking & sharing | |||
| Limited connection | Vista networking & sharing | |||
| Limited access to ethernet connection | Vista networking & sharing | |||
