Vista - Networks problem
Old 01-18-2009   #1 (permalink)
Vista Ultimate x64,
Networks problem
Every time I have to restart my computer the computer don't get contact with the network. But after several reboots it works. I have instlled the latest drivers.
What more can I do?
Old 01-18-2009   #2 (permalink)
Vista Home Premium x64
Re: Networks problem
I have the exactly the same connectivity problem with the Belkin wireless router. The PC connects to the internet every time when the ethernet cable is attached directly to the cable modem, but via the router, requires multiple restarts before a connection can be established. So far I have tried 2 different routers and 2 different PC's (the first running Vista 64 and the second a wireless laptop running XP 32 bit). I have also reinstalled the latest Belkin software and firmware, but no difference. The Belkin Vision router has a graphic display showing connections, and always shows the PC to be connected when first switched on, but losing the connection as Windows itself boots up.
Any advice would be welcome. Thanks, Ted.
Old 01-18-2009   #3 (permalink)
Vista Ultimate x64
Have you tried a different brand wireless router?
connect to 2 networks show in screen problem Vista networking & sharing
Multiple networks problem, limited connectivity Network & Sharing
created a network bridge, 'multiple networks' problem Vista networking & sharing
Problem with Wirless Networks Vista networking & sharing
Multiple LAN networks appeared.TCP/IPv.6 problem? Vista networking & sharing
