| Vista 64 Ultimate | WLAN Issues: "Partial" Con Loss Hello, I have some odd Problems with my WLAN Connection on Vista 64 SP1. I "loose" my connection to the Internet and IE fails to resolve any DNS querries. But I am still able to use any "open" connection. For example straming audio keeps working or Teamspeak works. (But only for a short while), but they die soon after that. The connection usually recovers after 1-2 minutes. Sometimes it get stubborn and it stays dead. When I disable the NIC and then reenable it it keeps working. The Problem seems to surface when i have many open connections. Ipconfig /all: ---------------------------------------- Windows IP Configuration Host Name . . . . . . . . . . . . : CleanStart Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Wireless LAN adapter Wireless Network Connection 3: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Realtek 8185 Extensible 802.11b/g Wireles s Device Physical Address. . . . . . . . . : 00-08-54-88-41-80 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 192.168.178.21(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Friday, January 30, 2009 6:35:05 PM Lease Expires . . . . . . . . . . : Monday, February 09, 2009 6:35:05 PM Default Gateway . . . . . . . . . : 192.168.178.1 DHCP Server . . . . . . . . . . . : 192.168.178.1 DNS Servers . . . . . . . . . . . : 192.168.178.1 NetBIOS over Tcpip. . . . . . . . : Enabled Tunnel adapter Local Area Connection* 6: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : isatap.{ECB2AA4E-DD4B-4F5E-85BC-E01302411 579} Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 11: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Physical Address. . . . . . . . . : 02-00-54-55-4E-01 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes ---------------------------------------- |
| ADSL link loss on "wake". Vista Ultimate and Linksys Router | Vista networking & sharing | |||
| "Property Loss" Message copying images | Vista General | |||
| "Not Responding" partial fix | Vista General | |||
| Vista Media Center "Loss of Signal" | Vista music pictures video | |||
| "Media unauthenticated" when bypassing WLan AutoConfig | Vista General | |||
