Vista - Odd WiFi card issue
Old 01-31-2009   #1 (permalink)
Vista Ultimate x64
Odd WiFi card issue
Hey guys,
First post here so hello everyone.
I'm having a odd issue with my WiFi card, I'm not sure if it is driver related or hardware, I have a "Belkin F5D7001" there are no Vista 64bit drivers for it, but Windows auto finds drivers for it and it works, kinda. Windows sees it as a Broadcom 802.11g Network Adapter.
My problem is it only runs at 11Mbps - I can set it to 54Mbps but the results are below;
Download Speed: 663 kbps (82.9 KB/sec ) Upload Speed: 263 kbps (32.9 KB/sec ) 54 setting
Download Speed: 3769 kbps (471.1 KB/sec ) Upload Speed: 1115 kbps (139.4 KB/sec ) 11 setting
I have tried this at different times same result, I have the power settings to max but still no good. It use to work fine on my old Netgear but they don't support 64bit, I can't seem to find any 64bit drivers that work with this one apart from the Windows one.
My net can do at least 8000 kbps as I have tested it with a hardwired PC.
Anyone have any ideas? Thanks in advance.
Old 02-02-2009   #2 (permalink)
vista ultimate x64
Re: Odd WiFi card issue
Its auto compensating for a weak wireless signal?
Old 02-03-2009   #3 (permalink)
Vista Ultimate x64
Signal strength is reporting as Execllent.
Old 02-03-2009   #4 (permalink)
vista ultimate x64
Thats entirely possible afaik. The true test would be to put the pc next to the router for a short period of time, them monitor what it reports and how it performs.
Edit Reports as excellant when in 11Mbps or 54Mbps mode?
WiFi Card will not find networks when > 2GB RAM Vista networking & sharing
Sharing USB WiFi card between Vista and XP Vista networking & sharing
identifying Wifi card in laptop Vista General
If I disable the WIFI card from the device manager, is it truly off? Vista General
PCI WIFI-TV Card Driver for Windows Vista Vista hardware & devices
