I'm using VMWare to run XP inside Vista ... it's a fairly basic problem, but a bloody annoying one, when I plug the network cable in, I can access the shares from the Vista side in WMWare XP, but when I use a wireless card/usb dongle, the share appears, but is not accessible, it says I do not have sufficient privileges, I'm confused to hell as nothing has changed via the sharing, only how it accesses the internet/network, but BOTH are on the same PC, so effectively, there is no access to the router!
Please help!!!
Jason
Please help!!!
Jason
