Solved Network sharing problem
Hello fellow members!
I have a issue that I cannot seem to figure out with my network sharing. I have a wireless network with 2 laptops running Vista home premium and 1 xp-pro laptop all behind a linksys router. At this point I have all computer seeing and sharing (only from public folders) fine.
Problem: I want to be able to share one of the partitons that I created on one of the Vista laptops(home premuim) as a share for backup, but other Vista laptop won't let me have access to it. It does however let me have access to the public sharing folder though. How can I access this Drive/partition?
What I have /have tried so far:
Network discovery is on
file sharing is on
printer sharing is on
password protection is on
all computers have same corresponding usernames and passwords
properties of the particular partition in question is configured to share.
All computers have the same workgroup name.
What else am I missing here?
Thoughts: What I am trying to do, in a nutshell, is to be able to use that one partition for backup images for all 3 computers(has a very large drive on that specific laptop) So I even though about maybe mapping that it into the public sharing folder, a workaround, if you will, but I'm not sure if it would give me the available premissions to be able to do what I need it for.
Any advice, ideas or solutions would be greatly appreciated.
    Hp-Pavilion/dv6929nr
    intel Centrino/dual core 5750 2Ghz
    Quantas
    4gb
    GM965/x3100 for battery consumption
    Realtech
    1200x800
    200gb
    My Central Home air and My auto air when mobile
    Logitech Laser/synaptics touchpad
    6200kbps down/273kbps Up
    Dv5 Pavilion entertainment Lappy, Vista 64, 4 gig ram, Centrino core2duo t6400, 800 FSB, Nivida 9200M GS, 320 Gb Sata 7200. Logitech 175watt Sound system
Hi makinit70462,
In addition to the sharing permissions Vista also has Security permissions which need to be set to enable the sharing. The sharing permissions work at a top level but the security permissions are part of the NTFS system and are in addition to sharing,
You will need to give ether the "everyone" group or at least the users that are going to be performing the backup "full Control" security permissions on the backup Drive.
If you right click on the drive and use the security tab to apply these permissions, (and let them cascade to any sub folders), this should remove the error you are recieving
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    Samsung 32" TV
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB
    68 MB Down 18.5 MB Up
Barman,
Thanks for your reply! Security tab is configured to allow full control to me as adminstraor and user as well for that drive/partition as well as the sharing tab being configured the same, but still same error with no joy. I can't figure out what else I can do.
Any suggestions are greatly appreciated!
Makinit
    Quantas
    4gb
    Realtech
    1200x800
    200gb
\\computerIP\c$ is the administrative share. Can you see it. Did you set up new shares for each drive and give full control to your user.
    16GB DDR667
    SAS RAID
Hi makinit70462,
a couple of more things to check :)
I am assuming that you are using the windows firewall, if you are not then you have to have ports 135-138 and 445 open to allow sharing through a 3rd party firewall.
If you are using a 3rd party the easiest way of checking is to disable the firewall temporarily.
Another thing to check is that the option, if available, on the router to enter the workgroup name is filled in correctly.
this is strange as as far as I can see you have everything correctly set-up
Doh! just seen Michael's post and that would cause exactly the error you're getting try re-sharing the drive as something like "BackupDrive" and hopefully that should fix things
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
    Internal
    External (USB3)
    NAS 4TB
Hi makinit70462,
recieving
BINGO! Ok the problem was that I did not have the everyone group shared. When I added a new share "everyone" as a listed group that did it.
thanks barman
I have gave you credit for this one.
    Quantas
    4gb
    Realtech
    1200x800
    200gb
The most important thing is that you have things working :D
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
    Internal
    External (USB3)
    NAS 4TB
