| Vista Business 32 | Vista CMAK routing problem Hi All! I have problem with vpn connection on Vista. I've used CMAK 1.3 to create connection. The connection creates two routes and does not change default route. This is the route file content: add 10.0.10.3 mask 255.255.255.255 default metric default if default add 10.0.10.5 mask 255.255.255.255 default metric default if default remove_gateway On XP VPN connection works fine. On Vista I can ping 10.0.10.3 and local network, but I can not ping external hosts. I get error 1231. This is route table if vpn connection is enable: 0.0.0.0 0.0.0.0 192.168.163.253 192.168.162.119 10.0.10.3 255.255.255.255 10.0.9.16 10.254.1.16 10.0.10.5 255.255.255.255 10.0.9.16 10.254.1.16 10.254.1.16 255.255.255.255 On-link 10.254.1.16 89.111.111.82 255.255.255.255 192.168.163.253 192.168.162.119 This is route table if vpn connection is disable 0.0.0.0 0.0.0.0 192.168.163.253 192.168.162.119 If vpn connection is disable I can ping external hosts. |
| Vista CMAK routing problem | Network & Sharing | |||
| CMAK in Vista? | Vista networking & sharing | |||
| CMAK and Vista RTM. | Vista General | |||
| CMAK 1.3 on Vista and VPN Server List | Vista networking & sharing | |||
| Windows Server 2003 Fax Routing and Vista print problem | Vista print fax & scan | |||
